The system button wont work on my white-rodgers thermostat, It doesn't do anything when I push it
  • 38 Answers
SOURCE: trouble code "malf" on my white rodgers thermostat 1F89-211
you need a new thermostat
Posted on May 07, 2009
  • 127 Answers
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Posted on Jun 29, 2009
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
liteswink
  • 99 Answers
SOURCE: Replacing WHITE-RODGERS manual thermostat with 3
Give me the old connection then I will cross terminal this with Honeywell thermostat. This will be fairly simple.
Posted on Apr 06, 2010
liteswink
  • 99 Answers
SOURCE: white-rodgers 1c26-101 owners manual, does anyone
Link: Installation Instruction
Posted on Apr 07, 2010
White rodgers 1f97 371
Is there anything on the display that says CHECK STAT or CHECK SYSTEM? This thermostat has built in diagnostics that would probably notify you with an audible chirp and a display name to the fault.
Nov 19, 2013 | Honeywell Programmable Thermostat Heater
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
How do I fix my my white rodgers f178 thermostat, no heat
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department.
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to heat then and raise the setpoint above room temperature. There may be up to five minute delay before the thermostat clicks in heating If the thermostat click this means its not a thermostat you have a problem with your heating equipment call your installer. If the thermostat did not click the unit should be replaced.
Let me know if you need anything else.
Jan 11, 2013 | White Rodgers White-Rodgers 1F85RF-275...
My wife placed the filter in the wrong way. Our White-Rodgers Thermostat is saying filter malfunction and showing a flame when I turned it to heat. I went and put the filter in the right way be the...
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To better assist you with this contact us directly at 18002842925.
Oct 27, 2012 | White Rodgers White-Rodgers 1F85RF-275...
NO DISPLAY ON UNIT
Pull your display off wall and see if your unit has batteries. If you have a blue wire or, a wire connected to the "B" terminal in your thermostat(the part connected to wall, this should produce the power to show display. If you do not have a blue wire, it is dependant on the batteries for display. Change out batteries and see what happens. Obviously with no display, your system won't work. If this doesn't solve your problem, replace the thermostat.
Apr 26, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
MY White rofers 1f78 is stuck
Reset operation the system must be at cool position then press UP, DOWN and TIME buttons simultaneously. If the reset did not work call the hometechline 18002842925.
Link: MANUAL
Jul 20, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
