How do i get the mode to be supported on my tv and also the recording on my hdmi box does not record my movies anymore help
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Posted on Sep 29, 2008
SOURCE: RCA DRC8052N DVD recorder
How dumb of me never realize after having this dvd player for almost 2 years that there is a hdmi button on the remote I thought the TV would recognize the signal automatically just like the rca and component inputs I never had to use that feature since I never had a tv with hdmi inputs till now I was paying real close attention to my remote and there it was a small black button with HDMI in small black letters right next to the set up button and I use that button often. when I pressed the button it gave me the option of 480i 480p 720p and 1080i as I kept pressing the HDMI button. It works fine Im glad I got it going I thought I would have to buy another player. There MY PROBLEM SOLVE. Hope this works for for anyone trying to figure out this problem unless they tried it already.
Posted on Dec 02, 2008
SOURCE: Basic Cable (no box); signal "in" to DVD Recorder (from TV)
Problem solved via tech support for Toshiba- thanks!
Posted on May 05, 2009
  • 7 Answers
SOURCE: How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Posted on Jun 06, 2009
SOURCE: YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Posted on Sep 23, 2009
How to enable and disable movie-record button?
To use the movie-record button, your camera must be in the live view mode.
When you are using the viewfinder (DSLR mode) you only can shoot stills. in live view, you can shoot movies with the little red Movie-record button and shoot stills with the shutter release button.
Sep 05, 2014 | Nikon D5300 24.2 Megapixel Digital SLR...
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
My problem is that i have a 56" philips with hdmi etc... i have my dvd recorder plugged in via audio video cable .... i have my cable coming thru hdmi... i cant get my recoreder to record whats...
Hello rpgscope,
I am assuming both your dvd recorder and cable is plugged into your tv? Conncet a composite cable (rca cable or aka red, white, and yellow cable) from cable box OUT to dvd recorder IN. That should fix the problem. I mention composite cable but if you another slot for av then go ahead and use that. Make sure you have AV connected from dvd recorder OUT to the tv IN. Also the cable box should be HDMI OUT to tv IN. If you have it connected like this, it should work. Hope this helps.
- Joe
Aug 30, 2011 | Toshiba Televison & Video
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Hi. I have recently purhased an Acoustic Solutions DVDRW300 DVD Recorder. I have no instruction manual and have no idea how to set it up or work it!! Please help as im totally useless!!
Hello!
I am assuming that you want to INPUT your TV/Cable Box to your DVDRW, and have the DVDRW then be able to OUTPUT to the TV.
Here's what you need to do:
1. Locate the OUTPUTS of your TV/Cable box at the back of your set. There should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI . Make sure that they are OUTPUTS. It'll probably say TV-out or just out.
2. Locate the INPUTS of your DVDRW. Similarly, it should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI. Ensure that they are INPUTS.
3. Match up the outputs to the inputs. Now, I have listed the OUTPUT/INPUTS going from lowest quality to highest quality. So let's say your TV has RCA, S-Video and HDMI outputs, and your DVDRW has only RCA and S-Video. HDMI is ruled out, unless you get a converter (which is pretty pricey). Choose which one, and buy/use the right cables.
4. Here are the connections for each type of OUT/IN. (TV/Cable >>>>> DVDRW)
  • RCA (Yellow/White/Red) >>>>> RCA (Yellow/White/Red)
  • S-Video + RCA (White/Red) >>>>> S-Video + RCA (White/Red)
  • VGA + RCA (White/Red) >>>>> VGA + RCA (White/Red)
  • DVI + RCA (White/Red) >>>>> DVI+ RCA (White/Red)
  • HDMI >>>>> HDMI
5. Connecting the DVDRW back to the TV. So now, you can record whatever is playing live on your TV. But you also want to play things from your DVDRW on your TV. Check the OUTPUTS of the DVDRW. It should have either the same jacks as the INPUTS. Check the INPUTS of the TV.
6. Follow Step 4, and 5. Note that for connections, you are going from the OUT of the DVDRW to one of the INs of the TV. Keep track of what INPUT on the TV you are connecting to.
Voila! Let's test it, though. Now, turn your TV and DVDRW on. Put in a DVD (a movie perhaps) in your DVDRW. On your TV, switch the channel to the INPUT channel you used. You should see your movie. If not, try another INPUT on your TV.
If it's fine, then let's try recording a TV show. Switch the channel on your TV to whatever you want to watch, say Cartoon Network. Put in a blank DVD in your player/recorder. Hit record on the player. Let it record about 2-3 minutes, and stop recording.
Switch the TV back to the INPUT which works, and hit play on the DVDRW. You should see what you recorded.
Hope this helps!
Mar 14, 2011 | Televison & Video
I can't seem to get it to record any shows off my t.v.
the hdmi connections are input only.
if the tv has scart sockets on the back, and the recorder also, connect to these. the tv's scart needs to be either 2 way or out put shown with an arrow pointing out of a box for output and a 2way arrow for 2way scart.usually scart socket 2 is 2way. set the recorder as you would normally but set the channel to tye av or scart that you are using. please note that video plus will not work on the scart socket. you may also have to set the output for the scart socket via the menu.
Mar 12, 2010 | Televison & Video
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
Your HDTV does not support HDCP
This is normal in HD 4250.Problem is ( box software).You need to disconnect HDMI cable from the box,or leave TV "ON" during recording.
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
