Question about Next Cameras
Vivitek D5000, angle warning showed, then image was black and white only. Cooling for 30 minutes didn't cure fault. Reset in menu next day brought back colour image.
SOURCE: LCD screen shows weird colours
Canon will fix this for free, regardless of the warranty situation.
Posted on Mar 19, 2007
  • 374 Answers
SOURCE: white screen lcd display
Your LCD is starting to go out. Call their repairs dept to have it fixed. 1-800-706-2534 option 2. Tell them that you have already talked to tech support otherwise they will make you call a bunch of different phone numbers.
Posted on Nov 26, 2007
  • 1689 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
SOURCE: only black and white!
I have the same problem. I instaled the driver with lot of problems but I made it work. Only in (black and red).
Who can help us
Posted on Jun 30, 2008
  • 919 Answers
SOURCE: White screen with black stripes, black spot
Sounds as if the camera would need to be sent to Olympus for service. You may want to call their Customer Service to discuss repair options and pricing. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on Dec 11, 2008
TV 24" bought 2 TV and brought to Brazil and my analog signal and the image is in black and white how do I use the TV with analog signal with color image
Check the color system settings. Enter its menu, and check it. If the set is a multisystem compactable one, set this setting to "Auto". Gopakumar Gopalan Google
The fault is really related to color system compactability.
Mar 27, 2014 | Televison & Video
Vivitek d510 projector has the power button blinking 6 times then the lamp light blinks 3 times. What does that mean?
do the next test. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Vivitek Televison & Video
Ipod touch will not turn on
Thank for contacting Fixya, I will be glad to assist you.
What you can do, in order to resolve this issue, is start by resetting your iPod Touch
(Note: this does not remove any settings, data or media you have installed in your device)
• To perform a hard reset, press and hold your Sleep and Home Menu buttons for approximately 10 seconds.
• Once your screen goes black, release both keys. (If you see a white Apple logo before you release the keys you have held the keys to long and will need to start the reset process once again)
• The next screens you should see after the black screen, is the Apple logo screen followed by the main screen.
Let me know if this helps.
-The MacTechTrainer
Nov 06, 2011 | Apple iPod touch
A "final warning to replace
Did you reset timer after replacing lamp?
Aug 23, 2011 | Vivitek Replacement Lamp
I have a vivitek projector which produces white and black horizontal lines through the image. The menu will not display and neither will any input. What exactly is the problem? I have tried...
I've got the same problem with my NEC LT75Z DLP projector.
I am currently trying to fault find the unit, but need extender cables and special plugs and sockets to achieve this.
It will most likely be a partial power supply fault or a processor board fault, since the lamp comes on and the leds and fans operate, and the colour wheel spins correctly.
Jun 18, 2011 | BenQ MP510 DLP Projector
Sir, its white small dots on complete screen, like sky with stars,
Place a white piece of paper about 1000mm in front of the screen and focus the image sharply.
Choose menu, image, advanced then select color manager.
go through the color options and check if some pixels are permanently on or off (ie small dots or black) instead of a uniform colour on the screen.
The DLP chip is most likely the faulty component
Mar 01, 2011 | Vivitek D825MX Projector
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
My canon powershot a95 display screen does not show an image when I am trying to take a picture. The image that is displayed is black with white lines and varies in the amount of black and white. No matter...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 10, 2009 | Canon PowerShot A95 Digital Camera
Vivitek 32 L32PL1A no picture, black screen
chek your power module.check your electrolytic capacitors both in the input & output side of the power module.
Oct 05, 2008 | Vivitek V37835 46 in. LCD Television
Black and white image
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 27, 2017 | Farenheit TID-730 7 in. Portable...
Cameras Logo
66 people viewed this question
Top Next Cameras Experts
Tony Parsons
Tony Parsons
Are you a Next Camera Expert? Answer questions, earn points and help others
