How do I use my merchteck bluetooth speaker model no. 1503121
How to pair my speaker to my devices
all of your devices might not be compatible with it .
Nov 15, 2016 | The Audio Players & Recorders
I can't pair my phone with a bluetooth speaker.
Switch speaker OFF. Power phone down count to 10 and power back up. Go to Phone, Settings - Bluetooth - Search for Devices. Turn Bluetooth speakers on. When found by the phone, click PAIR. If asked for a PIN Code, the default is 0000 (four x zeros).
Any problems COMMENT below my name with make and model of phone and make and model of speaker.
Jul 05, 2016 | Cell Phones
I have an ion ipa56c block Rocker. The battery is brand new. It gets a full charge and only last a few hours . Help
Block Rocker™ Bluetooth iPA56C - ION Audio
www.ionaudio.com/products/details/block-rocker-bluetooth-ipa56c
Block Rocker Bluetooth iPA56C provides up to 75 hours of on-the-go sound with its long-lasting ... A high-quality microphone is included to get you started.
RE: Block Rocker Bluetooth model differences - Ion Audio ...
community.ionaudio.com/ion.../block_rocker_bluetooth_model_differe...
Jul 6, 2014 - IPA23 - Explorer Bluetooth, Block Rocker Bluetooth, Block Rocker ...Besides the addition of another bluetooth port and the 75 hour battery on ... Bluetooth models IPA56B or IPA56C..... and between the last 2 what the differences are ? ... I have a model that says it's a iPA56B but only has a 50 hr. battery life.
Amazon.com: Ion Audio iPA56D Block Rocker Portable ...
www.amazon.com > ... > Karaoke Equipment > Players
Amazon.com, Inc.Amazon.com: Ion Audio iPA56D Block Rocker Portable Bluetooth Speaker System ... I work at gm and have bought 4 bluetooth speakers before this one for work use, ....block rocker battery power lasts only a few hours and blue tooth stopped ...
Amazon.com: ION Block Rocker Bluetooth Portable Speaker ...
Amazon.com, Inc.Ion Audio iPA76A Block Rocker Portable Bluetooth Speaker System with ..... I work at gm and have bought 4 bluetooth speakers before this one for work use, All of .... block rocker battery power lasts only a few hours and blue tooth stopped ...
ION Audio Block Rocker, Job Rocker, and Tailgater - Battery ...
noterepeat.com > ION > Portable Audio
Feb 08, 2016 | Tablets & eReaders
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Jan 28, 2016 | JBL Audio Players & Recorders
Speaker looks like a hand grenade, is Bluetooth or plug in. The cord that connects my iPhone 6, the speaker and into a USB port for charging (3 connections) has been lost. Can you help?
'the cord that connects my iPhone 6', well that is a lightning connector and is nothing to do with Bluetooth which is wireless.
Bluetooth speakers usually have a USB at one end and a mini-D connector at the other end. USB is a 5 volt charge.
Pick your model of speaker in the link and then with name and model, Google or search on Amazon for
<make of speaker> charging lead
bluetooth speakers Bing images
Jan 17, 2016 | Audio Players & Recorders
How do I connect ilive Bluetooth speakers to my tv?
If your TV is not Bluetooth-enabled (I have not yet read or heard about a Bluetooth-enabled TV model), you cannot connect any Bluetooth speakers to it.
Nov 30, 2014 | Audio Players & Recorders
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
How do i pair my x-mini kai capsule speaker with my phone?
Where the bluetooth options on your phone will depend on your phone.
So to put the speaker into Bluetooth pairing more slide the power switch to the right hand side. If the speaker has power then a blue light to the right should light up.
Once this is done you will need to find the Bluetooth devices option on your phone. This will be located somewhere under settings - connectivity.
When you locate the device in bluetooth devices, select it then select pair.
If you can't find the bluetooth options on your phone, comment on this answer with the phone name and model and I will see if I can find out for you.
Sep 11, 2014 | Xskn XAM11-B X-mini Kai Capsule Speaker -...
Making my craig bluetooth speaker discoverable
Through basic hacking, the code 0000 worked for me....
I wish it came to me sooner!
Craig Electronics CMA3532BT is the model number -
A tiny cylinder speaker - sounds pretty good for the tiny $$$ too.
MikeFilosa
Dec 02, 2012 | Craig Portable MP3 Speaker - CMA3016 White
Need Speakers
Bluetooth speakers are no less than any other popular gadgets and they are gaining in success rapidly. These wireless devices are the perfect match between you and your favourite music. Connect this with your smart phone and see how it fills your life with tune. Bluetooth speakers usually come in all shape and size, from potable to wireless and works elegantly keeping that same compatibility and gets connected with almost all kind of phones, whether it's a windows phone or an android and lets you enjoy better music than in-built speaker. PTron Bluetooth speakers will have good bass sound. MOST POPULAR BLUETOOTH SPEAKERS OF 2016 IJ Tech
Apr 17, 2008 | Insignia NS-DV2G MP3 Player
79 people viewed this question
 Grubhead
Grubhead
