Question about Simpson Washing Machines
My Simpson 750 espirit is leaking from what looks like the agitator shaft,agitator has lots of side to side play,can I reduce this play by retightening somehow or would seal be stuffed as well?
  • 49 Answers
SOURCE: hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Posted on Sep 30, 2008
2tone2
  • 7 Answers
SOURCE: 4T60E Transmission output shaft movement
Hi Caarl
The lateral movement in the output shaft is normal and nothing to worry about.
Posted on Nov 02, 2008
chessmaster2
  • 160 Answers
SOURCE: 2000 Mitsubishi Galant, EA3A 2.4l motor. Oil leal
it could also be the oil pan gasket, or the manifold gasket. if it's the manifold gasket, when you remove the manifold to replace it, take the time to clean out the mixing chamber. it'll be filled with gunk and cleaning will improve gas mileage.
Posted on Dec 05, 2008
  • 52 Answers
don't use 20w50 that is too heavy an oil for that motor. the most i would use is like a 10w40 and that is a last resort. your valves need adjusting or the hydraulic lash adjusters may be gunked up. there is a chemical called auto-rx (search web) that could help you out. just follow the directions for it. the only other oil seals i can think of are oil pan gasket, oil filter gasket, rear main seal, valve cover gasket.
Posted on May 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: simpson washer only agitates in one direction
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
How to remove agitator from Simpson 750 esprit
Look down inside the agitator. At the bottom is a hexagonal bolt. You need a 10mm socket on a long extension bar to reach it and undo it. Then pull agitator up & out.
Feb 15, 2017 | Simpson Washing Machines
Simpson 550 top loader. How do I remove agitator and clean under the bowl
Pull top part of agitator off an there should be a locknut visible 10mm I think,remove locknut an agitator should come free,it may need a few light taps to release,pretty sure its the same as my 750...hope this helps an good luck.
Dec 27, 2016 | Simpson Washing Machines
How do I remove the agitater from simpson washing machine espirit 550 5.5kg
most machines with verticle and turning agitators have a cap on the top which may be removed with a small ***** driver. that should give you access to dawgs and release nut. use a rubber hammer to gently tap and loosen if need be.
Apr 03, 2016 | Simpson Washing Machines
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Operating instructions for 36P450 Simpson washing machine
I have a Simpson espirit 450 andthe agitator has a hole. I have beensent a new one but have no idea how to remove the old one. I can loosen the bolt at the bottom but can't can remove the bolt. Unsure why or what to now ? Would love some help... Thank you
Dec 01, 2010 | Washing Machines
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Oct 14, 2010 | Washing Machines
A necklace has dropped down under the agitator in my Simpson Espirit 700, how do I get it out. Thanks - ****
Hi just read your posting.Now do you still require help?If you do then pull the middle of the agitator out and shine a torch down the center.You should see a 10 mm bolt.Grab a socket set and turn the bolt anticlockwise to remove it and then lift the agitator out.Please reply on how you got on and for more advice if needed.Looking forward to your reply.
Aug 17, 2010 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
