Question about Samsung Televison & Video
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
  • 1,917 Answers
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Posted on Dec 27, 2016
No sound on my Kogan 49" smart TV when connected to Foxtel or DVD through HDMI inputs
could you check on tv setting for hdmi that its in digital input and not external input. as sometimes the device settings are wrong, also its best to try a different hdmi cable as sometimes the cable can become damaged.
Jun 30, 2017 | Televison & Video
I would like to connect my DVD player and Foxtel to me tcl smart tv but have no idea how it do it. Can somebody please help me.
depends on the output from Foxtel
is it antenna rf coaxial on foxtel ?
is it hdmi output on foxtel box ?
is it an AV RCA cable output on foxtel box ?
what does dvd player use for its output ?
Suggest you google these connection interface types and work out what is the output types
if rca then use av input on tv
is hdmi then use hdmi input on tv
then use select input source on tv to switch to whatever you used.
Jan 20, 2017 | Televison & Video
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
How do I link my Samsung sound bar to my Techwood 55 inch smart TV.
What model is the tv and what model is the soundbar? Trying to connect via cable or bluetooth?
Jul 20, 2016 | Samsung Televison & Video
Hdmi ports not working
Disconnect EVERYTHING for a few minutes - reconnect and restore all factory settings.
Jan 26, 2014 | Samsung 55 inch UA55ES8000 Smart 3D LED...
Samsung 55" turns ON/OFF by itself and will not connect to wifi network
I have the same issue. I read and watched online tutorials about the compositors but after opening the set up I was unable to find any that had gone bad. I was able to upgrade the software by using a USB thumb drive but the issues are still there. I'm thinking of swapping out the motherboard and/or the power board next to see what the fix is.
Feb 24, 2013 | Samsung UN55ES7100 55" Class Smart TV 3D...
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Have just bought a new samsung led lcd tv have got the tv and foxtel working but cannot seem to get the panasonic dvd recorder working just keep getting a no signal sign,the dvd runs through the component...
I am guessing slightly as you havn't mentioned the model, but I think you need to change the output setting on the panasonic to component before it will work, connect it up to your old set or to the new one using scart, go into the menu and select component output, the pic will probably disapeer, then connect to the new tv via the component connection and it should work
Nov 27, 2009 | Televison & Video
How to connect my dvr with cable tv
I Do believe that Foxtel puts a block on movies so you cannot copy them..
Mar 30, 2008 | Samsung DVD-R155
Televison & Video Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
