Question about Dishwashers
Our shu66c05uc Bosch dishwasher does not dispense the detergent.
Our shu66c05uc Bosch dishwasher does not dispense detergent, the detergent door at times does not open and we have found the door still in the close position at the end of the cycle. Is there something we should be doing to prevent this sort of thing? Lately, our dishes have not been coming out very clean and we would have to go through another cleaning cycle-what a waste!!! Help!
  • 205 Answers
Most likely the solenoid that operates the lever on the detergent door is faulty. Only solution is to replace the whole dispenser, unfortunately. It is possible that the controller is not activating the dispenser but less likely.
Posted on Jul 21, 2009
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
Detergent door opens prematurely.
Sounds to me like something is off time. Try opening it up and cleaning around all moving parts. Or maybe try resetting the whole machine.
Dec 22, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
My detergent dispenser door does not open. It is NOT cloggy inside. Does anyone know if there is a pre-rinse before main-cleaning? I.e if I can just put the detergent into the machine directly? Thanks
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 30, 2010 | Bosch 24 in. SHV99A13UC Dishwasher
Should the detergent dispenser door be open once the cycle is done? I always saw it as open so I knew the detergent had been emptied, but now when I open the dishwasher after completion of all cycles the...
Hello, Yes the door should be open at end of wash,either the dispenser is faulty or the p.c.b. If you dont want to go to the exspense of new dispenser etc.Try putting tablet ( I presume you are using tablets ) in the cutlery basket.If you are using powder then it will have to be repaired.
Hope this helps.
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH DISHWASHER SHU33A DETERGENT DISPENSER WON'T POP OPEN
try some liquid detergent, somehow these powder and tablets tend to stick in and keep the door shut...
Sep 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU4322 Dishwasher leaks in the door
Detergent dispenser gasket or faulty air vent.
Feb 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Detergent dispenser spring door is either missing the spring or broken. In any case it opens but is no longer spring loaded. I can't figure a way to remove the assembly unless I have to take off the front...
Door just pulls off, you will require a new door, spring & possibly a catch. Spring fits onto pin on door and other end onto pin on holder, then fold spring on its-self and re-instate onto runners/slide. Paul Winn Appliance Services. (Cumbria)
Apr 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher detergent door spring
I ordered and received the new Bosch dishwasher detergent door, but do not know how to repalce it!
Jan 23, 2008 | Dishwashers
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
389 people viewed this question
Top Dishwashers Experts
