Question about Samsung Cell Phones
Unable to show delete sign at top of Samsung computer screen, only when pressing home icon? will it activate.
SOURCE: unable to connect to my device
I had this problem with my YP-U3JZB, and this worked:
Plug player into USB port. Then do: Control panel > System > Hardware tab > Device manager > Portable devices (expand and locate name of device, eg "Samsung YP-U3") – right-click and select “Update driver”, follow prompts.
This worked without installing the Samsung media player – Windows Media Player 10 or 11 will then recognise the device, for syncing, etc.
(found this solution in another forum, can’t now locate – anyway, props to them!)
Posted on Jan 09, 2008
SOURCE: "HOME" Icon and "Edit Home Icon" not working
you have to connect the pink / blue wire to the 'parking brake' or just ground it
when it's grounded the unit thinks the parking brake is on and therefore 'safe' to edit
Posted on Mar 04, 2008
  • 3940 Answers
The Caps Lock LED flashing indicates a Motherboard failure on the system
Posted on Jun 17, 2008
  • 14 Answers
SOURCE: email unread icon on home screen always shows 2 unopened
I had the same problem If you SAVE any messages they move to your SAVED folder they will show as new just go into the file cabinet icon and see if any messages are there all you do is open them and the icon should go away
Posted on May 29, 2009
  • 1267 Answers
SOURCE: I recently bought a Sylvania 7 inch netbook sold
Your OS should have an icon on the desk top that says WIFI Power, it is blue in color and this icon turns the WIFI on and off. When the button says off, the WiFi is on, the idea is that it is waiting for you to turn it off. If that is not on your desk top, turn the machine over and look for a small hole 1in diagonally right of the data plate. insert a tooth pick in that hole a depress gently to reset your machine.
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at:
Posted on Dec 28, 2010
How to delete extra pages
    1. Remove Home Screen Panel
      1. From a home screen, pinch in on the screen. Place two fingers on the screen and bring them together.
      2. Select and hold the appropriate panel then drag it to Remove (located at the top).
      Add/Remove Home Screen Panels - Samsung Galaxy Tab 2 ... Verizon Wireless
  1. How to Manage Home Screen Pages on the Android Tablet ...
    To edit Home screen pages, pinch the Home screen: Touch the screen with two fingers and drag them together. You can then manage Home screen pages. Generally speaking, to rearrange the pages, long-press and drag it to a new spot. When you're done, touch the Back or Home icon.
    Verizon Wireless
Jan 09, 2016 | Tablets & eReaders
How to remove an icon from home screen
On most Android tablets, you simply press and hold the icon until the screen changes modes (to arrange). Then you should see an option to delete/remove at the top of the screen. Just drag the icon to the top of the screen and it should leave the home screen.
Nov 18, 2015 | Tablets & eReaders
How to delete unwanted music
is it a galaxy samsung tablet ?
in apps find an app labelled as my files with a folder icon above it
under root/sdcard/music
find music file click on the little box left of the file you wish to delete
a green tick will show in the box
once you do that you will notice at the top of the screen a dustbin icon has appeared in the right top side. press this icon to delete the file. then click on yes when it asks if you want this item deleted.
Then double click back icon to get out of my files
back icon is bottom left corner on black part of screen.
Mar 18, 2015 | Samsung Tab Tablets & eReaders
Netflix won't recognize my log in
Google translate from Danish:
Test your Internet connection
Make sure your iPad, iPhone or iPod touch has an Internet connection. You can check this by trying to visit a website (eg. in a web browser (eg. Safari). If the page does not load, or loads slowly, try to turn on and turn off the unit's Wi-Fi connection. If you still can not connect, there may be problems with the Internet connection.
Check the date and time of your Apple iPad, iPhone or iPod touch
If the date and time on your device is very different from the current date and the current time, it will cause problems with videoafspilning.1.Tryk icon (Settings) on the home screen.
2. Press General (General).
3. Press the Date and Time (Date & Time).
4. Press the Set Date and Time (Set Date & Time) .?Hvis date and time is not correct, adjust this until it fits with your time zone.
?Eller switch On / Off (On / Off) On (On) in the Set automatically (Set Automatically).
Install Netflix app again
1.On the main menu, press the Netflix app and hold your finger on it until the icon vibrates.
2. Press the X in the upper left corner of the Netflix icon, and then press Delete (Delete).
3. Go to the App Store, search for "Netflix" and choose the free Netflix app from Netflix, Inc.
4. Press the Install button (Install). You must enter your password to iTunes to install the app.
5. When the app is installed, tap the Netflix icon.
6.Indtast e-mail address and password for your Netflix account, and then tap Sign in (Sign In).
Mar 06, 2015 | Apple iPad Tablets & eReaders
How to delete an icon
Long press the icon. While doing that, you will see a REMOVE appear at the top of your home screen. While still holding the icon down, drag it to the Remove and let go. This should delete the icon.
Jul 17, 2014 | HTC Sensation
Widget Removal
Hi if you want delete anything from your home screen press and hold it for few seconds and you should see depends from your os bin or remove sign at the top or bottom of screen then drag it there and it's done.
Apr 14, 2014 | LG Xpression MobiPhone - Red at&t
How to delete apps in iphone 4s china phone
To delete apps on an iPhone you simply press down with your finger on the icon of the app you want to remove and don't lift your finger off the screen until the icons start giggling and an x shows up on each of the icons. Now press the x to remove any app (icon) you don't want. When done press the home button to get out of delete / move mode. Some icons you cannot remove, such as system icons.
Oct 14, 2013 | Computers & Internet
How can I hang up?
okay heres how you do it..
Slide your finger from the very top going down
the wifi, bluetooth, gps ,sound and auto rotation screen will be open
on this page you will see that your call is still active
just press clear and you will hang up the call
after this just press the home button on your phone and your back to the main menu
Jan 17, 2012 | Samsung Galaxy S GTI9000 Smartphone
the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
it starts automatically but in your case it is not starting
to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
when you do this a task manager shows up in a window
in task manager window click on file, it will be located on the top left portion on task manager
now click on "new task(run)"
this opens another window, in that window type
without the quotes "" and press enter
this will bring you icons and task bar at the bottom of the screen
Sep 29, 2009 | Computers & Internet
My calendar program is missing..
1.To hide a Home screen icon, complete the following steps: Select an icon on the Home screen of the BlackBerry smartphone. Press the Menu key.
Click Hide Icon.
2.To show a hidden icon on the Home screen, complete the following steps:
Press the Menu key. Click Show All.
3.After the Show All option has been selected, to show a hidden icon, complete the following steps:
Select the transparent icon on the Home screen that you want to make visible.
Press the Menu key.Cancel the Hide Icon selection.
4.If not able to find Install Blackberry desktop Manager ...Take Backup.. reinstall the application from application loader in Blackberry Desktop Manager
Aug 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
