Question about Cameras
I have an IC5000 projecta 7 stage charger and it has stopped charging. The top red light comes on for power and none of the other lights come on. The charge rate does not seem to be working. . john
SOURCE: My phone will not show it charging and will not turn on, red light flashing
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Posted on Jan 11, 2008
SOURCE: Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Posted on Jul 11, 2009
  • 7 Answers
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
SOURCE: the red light does not come on when I charge the
I have bad news for you, most likely, you have a drop dead battery.
But there is good, it can be replaced, if not afraid of a screwdriver and soldering iron:)
If you disassemble the unit, you'll find the battery if you own a soldering iron it can be easily replaced by the same or even greater capacity.
Posted on May 14, 2010
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
My projecta 15a 7 stage batterie charger stopped working.was a bit hot and now no power, nothing . .???? Any ideas please
you must check your battery charger as i think you have to replace the charger or you can get it repair for more help you can connect with us on the given link http://toolsnyou.com/
Dec 08, 2017 | Cars & Trucks
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Laptop shut down seconds after pushing power botton
first thing that you need to determine is has your battery run flat and is your charger working...you will know this simply by leaving your lap top off and plugging in your charger...if you get charging lights come on then the charger is fine and it implies something is going on with the laptop which i can get to next....if you dont have any lights come on at all then it implies either your charger is faulty/broke/or fuse in the plug is faulty or the charging port in the laptop may have a fault/loose connection....if you do have lights (hence power) then you need to know at what stage of the power up it fails at...as boot up happens in stages....first bios (black screen with the text that flashes up)...then hardware (just at the end of the bios screen) then once it detects no faults or issues it will go into software mode (the point when your operating system i.e. windows screen starts up...and knowing the stage of shut down could help determine whether you are looking at bios/hardware or software problem...sorry if any of this is patronising...not sure what level of user you are...hope this helps
Jan 29, 2012 | Computers & Internet
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My Dell Streak 7 Tablet will not charge. When the charger is plugged in, it does nothing. No light at all. When the power button is pressed, the front lights come on momentarily and then the charging light...
Aug 11, 2011 | Dell Streak 7 Tablet Android
Battery won't charge
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
