Question about Saws
I'm looking for a gear shaft for a 12" Ryobi Sliding Compound Miter Saw model EMS 2431 SCL
4 Suggested Answers
Kazong
  • 152 Answers
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Posted on Jan 13, 2008
  • 17 Answers
SOURCE: instruction manual for bosch sliding compound miter saw model pcm1800 sd
Go to the wed site and add the model number
Posted on Mar 22, 2012
  • 50583 Answers
SOURCE: do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Posted on Oct 12, 2016
I have a Ryobi mitre saw EMS 1442L that has a stripped output assembly gear. According the parts listing this part is no longer available. Does any other model part fit this?
it may be worth investigating if later driven and pinion gears will fit the shafts of your unit
It is a way that ryobi has of making older unit obselete
if you research the gears by shaft size , number of teeth diameters thickness etc you may get something but look for matching gears and not just the stripped gear
you may get gears from another manufacturer/model to suit
Dec 13, 2017 | Ryobi Saws
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
adjust as necessary
Oct 12, 2016 | Saws
Why isn't power getting transferred to saw blade?
look for a shear pin in one of the gears that has done it's job and has prevented mass destruction of a gear by shearing off. Find the gear that is attached to the shaft that drives the blade and see if you can turn I while holding onto the shaft
May 28, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
What is the middle of the road, good Compound Miter Saw? I want to replace all of the baseboards & door trim in my house. I want to do a good job of it.
I have a chicago tools 12 inch sliding compound miter saw that I'm pretty happy with. I got it at Hatbor freight on sale for $119.99 plus tax. Regular $199. I'm favorably impressed with the quality of workmanship and ease of use.Expecially at that price. I Also have a very good 10 inch black and decker but it is not compound. Hope that helps.Thanks
Nov 13, 2010 | Ryobi Saws
How do you unlock 10" ryobi miter saw ?
When you are facing the saw look on the right hand side in the area where the arm pivots. There will be a silver shaft with a groove just in front and slightly lower than the pivot. If you hold down slightly on the handle and pull out on this shaft it will allow the arm to lift up. Locking the arm down is reverse.
Here is a link to the owners manual for this tool.
http://www.ryobitools.com/product_manual/file_url/378/TS1342L_329_eng.pdf
Mar 07, 2010 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Wobely blade
sounds like the bearing is going out on the blade shaft
Feb 10, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Craftsman 10-in. sliding compound miter saw
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
63 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
