Question about Garden
Parts diagram for battery on 24' 8.5 rear ride mowerr
Why does Yamaha Grizzly 24-Volt Battery-Powered Ride-On stop after riding about a minute or so. It will start back after a minute or 2
Hi, Drexell you may have a faulty battery connection for this situation I would call my local dealer (Walmart) or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Modified Power Wheels The Definitive Troubleshooting thread
deneyen com rnleri deneyenlerden renin
Yamaha Grizzly 24 Volt Battery Powered Ride On Camo
Amazon com Customer Reviews Yamaha Grizzly 24 Volt Battery Powered Ride On...
Apr 11, 2016 | Yamaha Motorcycles
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
I need a diagram of the rear axle parts
Darvon, it looks like there are Woodruff keys on each axle shaft so yes there is a keyway. See the link below, on page 8 is the axle diagram. Good luck!
http://www.husqvarna.com/ddoc/husi/husi2011_naen/husi2011_naen_yth22v46xls_532445750r3.pdf
Aug 20, 2015 | Husqvarna YTH22V46XLS 46"" Riding Lawn...
My BX23 rear yellow lights flash all the time...even when tractor is turned off. I have disconnected the battery cable to stop the immediate problem but need to see the wiring diagram to figure out why...
The hazard lights are wired so they will flash when the hazard switch is on, regardless of whether the tractor is running. Assuming you have tried flicking the hazard light switch on and off, and the lights flash no matter what position it's in, then I think the hazard light switch is shorted. Pull one of the wires off the back of that switch to stop the flashing, then order a replacement switch - it's not an expensive part. Good luck!
Jul 07, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Need manual for 48'' hausqvarna riding mower yth2448, 24 hp ELS for mower deck belt installation.
Hi..my name is Keith...and you can go to an online lawn mower parts site and they will have a parts diagram of the deck and it will show how the belt is installed....one of the sites is.. www.outdoordistributors.com ..i hope this helps
Jul 07, 2009 | Garden
Brocken sway bar bracket for craftsman riding lawn tractor/48"cut
see if you can find a diagram of your model online there should be something
May 31, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
