Question about Coffee Makers & Espresso Machines
My b31 mini has never spewed out. Do I still need it fixed? My receipt is of course, long gone.
My b31 Keurig is leaking from the bottom. What can I do?
if it is anything like my BUNN you will have to buy a new one . they won't fix .
Jan 05, 2015 | Keurig B31 Mini Plus Brewing System
This is a recall, how do I get it fixed
Go to Keurig's website and follow the instructions.
Dec 26, 2014 | Keurig B31 Mini Plus Brewing System
Keurig B31 Mini Plus Brewing System not working
There is a transformer that take the 110 voltage and reduces it to 13.8 or 14 volts depending on your unit model, it runs an electronic board or little computer in the coffee maker. It's the brains of the coffee maker. I would say you fried the transformer and possibly the electronic board if the high voltage made it past the transformer. I have replaced the transformer in our sons Keurig and that fixed his problem but he didn't plug it into 220v. The transformer is not expensive, an eBay item at around $15 or so. Taking the unit apart is not an easy thing to do. But if your handy you could figure it out and test the transformer to see it it's putting out the right voltage. Just check the voltage tag of the one that it came with so you can order the right one for your pot.
Apr 21, 2014 | Keurig B31 Mini Plus Brewing System
Keurig mini plus b31 only half cup of the water dispenses
Reset the out-flow and dispensing format. See Manual for instructions.
Feb 16, 2013 | Keurig B31
Mini keurig stops brewing and blows tops off k-cups
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Manual for Keurig B31
Call 1-866-901-2739 for a manual.
Aug 23, 2012 | Keurig B31 Mini Plus Brewing System
Keurig B31 one cupcoffee maker users mannual
Keurig calls the B31 the Mini Plus Brewer. The manual is available from the Keurig Customer Service site: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The direct link to the English version of the Use and Care Manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/B31%20UCG%20ENG_FRE.ashx .
I hope this helps.
Nov 08, 2011 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
