Question about Cell Phones
4-Digit pin for movie 42588 - Cell Phones
I bought a netflix prepaid card and I get figure out how to load it on my computer to watch movies
To redeem your Netflix Gift Card:
  1. Go to netflix.com/redeem.
  2. Scratch the foil off the back of your card gently with a coin.
  3. Enter the 11-digit PIN code.
Aug 06, 2017 | Computers & Internet
I forgot my roku pin number
I think this will work. First log into your Amazon account. Then go here
http://www.amazon.com/roku/ (it should have redirected you here, if not then click here)
http://www.amazon.com/gp/video/ontv/rok ... v_faq_roku
Then click on the "Edit purchase PIN & Payment settings" button, scroll down to "Your Purchase Pin" You should be able to see your old pin, if not just make one.
PS. The Amazon pin is the 5-Digit pin you enter to buy or rent movies in the Amazon channel. If you are talking about the 4-digit pin you enter so you can add channels in the channel store in the Roku. Go here and log into your Roku account.
https://owner.roku.com/Account/Login/
Click on the Parental Control and you should see your pin, and change it if you want, or disable or enable that feature.
this is all i could find on the internet hope it works for you.
Dec 10, 2016 | Roku Televison & Video
My harley wont start
Key fob MUST be present near bike!
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
TO ENTER NEW PIN:
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
Aug 10, 2014 | 2011 Harley Davidson FLSTC Heritage...
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
Pin number for mgo movie
You can check your Roku account and look for the Channel Store pin.
Feb 14, 2014 | Roku XD Streaming Player 1080P Wireless-N...
Need parental level 4 digit password for magnavox MWD 2205 DVD player
EASY PROCESS LOL
Instructions
    • 1 Press the "Stop" button on the remote if you are currently watching a movie.
    • 2 Press the "Setup" button. A menu will appear on the TV screen.
    • 3 Tap the "Left" and "Right" arrow buttons until "Custom" is selected. Press "OK."
    • 4 Select "Parental." Press "OK."
    • 5 Enter your four-digit PIN number. If you forget or do not know your code, enter "4737" to override the security. Press "OK."
    • 6 Tap the "Up" or "Down" buttons until "Parental Level" is selected. Press "OK."
    • 7 Select "All." Press "OK."
    • 8 Press "Setup" to exit the menu. The MWD7006 is now unlocked.
Sep 21, 2012 | Philips Magnavox DVD/VCR Dual Player
Lost key fob how to turn off alarm?
You'll need the PIN number.
If you don't know it, you'll have to change it to a 5 digit PIN number you select.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Nov 06, 2011 | 2008 Harley Davidson FLHR Road king
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
