Question about kawasaki Quad Bikes
2002 kx 250 2 stroke wont start
I was riding my 2002 kawsaki kx 250 2 stroke . it was running fine until i put some gas in it that my friend mixed, not sure how much oil was in the gas. anyways i rode it for five minutes after putting in the gas and stalled while i was i driving slowly in first gear. i pushed it for while and it finnaly started again. only to stall out after 30 seconds of riding. almost sounded like it was flooded for some reason. someone help me
  • 850 Answers
Sounds like too much oil in the mix add more gas & clean spark plug
Cheers Rob
Posted on Jul 21, 2009
When i start up my kawsaki kx 250 2stroke with the choke on it revs real high until i push it down is this normal
Yes.... try to turn the choke off as soon as possible after start, a cold motor reving hard is not a great idea!.
Cheers.
Nov 29, 2013 | 2007 HM CRE F250R
I have a ktm 250 sx 2-stroke. It has a new piston and new cylinder. bike ran great before it needed the repairs. Cranks on first kick. Run good but it leaks the pre-mix everytime i ride it and it won'
Where is it leaking from? If its leaking, that's more than likely why it doesn't run right, the fuel/air mixture is off. Also, I wouldn't continue to run it until the leak is fixed as it may damage the motor from not lubricating properly.
Aug 14, 2013 | Motorcycles
I just purchased a 93 kx 125 and it wus runnig fine until i tried to open it up all of a sudden while im riding the bike just locked up nd cut off i have no idea why
is the engine locked, up will it kick over if not sounds like a sieged up piston did you mix oil and gas this bike is a 2 stroke which will require mixing oil and gas not just straight gas
Jul 04, 2011 | kawasaki Jetix 50 Motorcycles
My kx 250 has no compression i put reg gas in and rode i think ran out of gas then tyred to jump it and it siezed up and now i try to kick it over and it gos half way and no compr
If it's a KX it's a 2-stroke and requires oil to be mixed with the gas. If you didn't have a gas oil mix, it is probably seized and maybe even damaged the crank. These bikes have excellent owners manuals that have all the info required to rebuild the motor, and 2 strokes are fairly simple. Good luck!
Jun 07, 2011 | kawasaki GT650S Sport Comet 650 S...
Motorbike wont start after running engine kawasaki kx 250 if i ride my bike for 2 minutes or 50 minutes when ishut down the engine it will not start again until i clean the spark plug
possible bad rings allowing excessive oil seep up and wash spark out on next fire. do a compression check, ck for proper spark, and fuel....hope this helps
Sep 13, 2009 | 2003 kawasaki KX 250
What is the oil mixture ratio for a 2005 kawasaki 250
Use TWO STROKE ENGINE OIL in the pump. If not using an automatic oil pump, then mix the gas and oil 32 to 1. That equals 4 ounces of TWO STROKE ENGINE OIL to one gallon of gas. NEVER use motor oil in the gas. Only two stroke engine oil.
Aug 31, 2009 | 2005 kawasaki KX 250
I have a 2005 kx 250 2 stroke and it keeps eating plugs
NGK brand spark plug BR8ECMVX is the stock plug for the bike. The proper gas / oil mix is 32 to 1. That means 4 ounces of 2 stroke oil per gallon of gas. The posting was not clear as to just what the problem is. If you are burning up plugs there may be a air leak in the intake system making the bike run lean. A lean fuel mix runs hot.
Jun 24, 2009 | 2005 kawasaki KX 250
86 kawasaki kx250 rich mix problem
"Learn to like smoke for awhile. Smell the aroma". Pardon the humor. I couldn't resist. Chances are there is oil built up in the crankcase. It is going to take some time for the oil to dissipate. How long? I don't know. It all depends on how much is in there. Cleaning the muffler is no help since the oil burning is coming from the crank not the muffler. If you are careful, and keep a vigilant eye, you could cut the gas/oil mix in half to 64 to 1 instead of the normal 32 to 1. That would mean only 2 ounces of oil per gallon instead of the normal 4 ounces. Let the crank add the rest. This will help burn the crank oil excess, but BE CAREFUL. When the crank drys up you had best not ride until more oil is added to the gas.
A “very helpful” rating for this answer? Thanks!
Jun 15, 2009 | 2003 kawasaki KX 250
Spitting black
I have an 06 cr 250. I used to mix my fuel at 32:1 and it ran fine for a year or so as of late it's been fouling plugs every single ride. I've ridden 2-strokes all my life and know how to ride the powerband but lately its been spitting oil out of every seam in the exhaust. It used to maybe have a couple drops after a ride out the end of the pipe but now its leaking from the connection from the case, the pipe to muffler connection and a lot out the back of the muffler. i switched to 40:1 about a month ago and that's what is happening, i couldnt imagine what it'd be like if i left it at 32:1. I took the carb out and looked at my jet sizes, they are both a size smaller than stock. Any help? Also, the bike is so tempermental that I have to have all my gear on when i start the bike because I cant take my hand off the throttle for even a second or else the bike will foul the plug and die literally within 2 seconds. I know they arent meant to idle but its kinda extreme. my friend has a 2005 cr 250 and mixes 32:1 has no problem, can start his bike on the stand and walk away from it for 5 mins and put his gear on.it'd idle for at least 10 min before it'd die, but he'll kick it and it'd start right back up. I've heard running bean oil would help, but I've also heard it has a tendancy to seize up the rings? any truth in that? ,I would try more gas in your mixture, before you start changing everything. Its all in the way your ride, some people can do 32:1, some 40:1(me), some 50:1. ,,,
Nov 10, 2008 | 2003 HM CRE 250
kawasaki Quad Bikes Logo
361 people viewed this question
Top kawasaki Toys Experts
 binay biswas
binay biswas
Gregg Mahin
Gregg Mahin
Vernon Taylor
Are you a kawasaki Toy Expert? Answer questions, earn points and help others
