Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi espresso machine has a water empty fault but is full of water.
The magnetic float is free and working properly
    Master:
  • 469 Answers
The magnetic float is free and working properly Emergency Vehicle Kits And Winter Season Travel AmanStino
Posted on Dec 27, 2016
Testimonial: "Not related to my question"
My Delonghi Magnifica automatic Cappucino machine has the "fill tank message on screen all the time but the tank is full and properly positioned and driven right into position. What can I do?
There will be a float in the tank, if it isn't floating then that will be the reason. Solution would be new tank or jam something plastic underneath it to trick the sensor. You will need to do a visual check in future. On the other hand if the float is floating then you will have a sensor problem which someone else will need to help you with.
Feb 24, 2015 | DeLonghi ESAM3300 Magnifica...
Delonghi problems
I had a similar problem. I fixed it by putting a magnet on top of the float inside the tank - described in the link below. I advise covering the magnet with caulk.
http://www.fixya.com/support/t1898311-water_container_full_but_low_indication
Jul 20, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
Water is not registering displays says no water when tank is full. what can i do?
Check and see. If there is a float still in the water tank.. It's a magnet. Sometimes they stop floating then machine thinks there is no water..
Oct 19, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Saeco Royal coffee machine is displaying 'empty water container' and it is full - what is the problem
Is the floating magnet in the water reservoir floating ? If yes, you will have to check:
1) the micro switch which is located just beside the magnet (open the machine to check it with and ohm-meter) Check it with a small magnet that you have
2) if the micro-switch is OK with a hand-held magnet the floating magnet may be de-magnetized
3) if everything above is OK, the input on the control board is perhaps defective
Mar 23, 2012 | Saeco Royal Cappuccino Espresso Machine
Display on Saeco Magic Comfort+ says "Fill Watertank" even when tank is full. Removing and resetting does not help.
Hi
This is usually a magnet in the water tank or sensor inside the machine. First do you have the grey magnet in the water tank? If no magnet in the tank, that is the problem. The magnet floats when the tank is full and sinks when its empty. It sends a flux signal to the sensor inside the machine. If the sensor is bad inside it doesn't pick up the flux field and you get the "water tank empty" display.
May 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
We have a Solis Master 5000. The digital reader says the water tank is empty when it is full. We have owned the machine for about 4-5 years and we have descaled pretty regular and recently took apart and...
Hi
You need to check that the magnet in the water tank is floating when the water is half way up in the tank. If it is not floating or is missing, that is your problem. If it is floating you may have a bad sensor inside that reads the magnet or the magnet is bad..
May 14, 2011 | Solis Master 5000 Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Fill Water Tank But Water Tank is Full
Check the little black rectangular box which is in a plastic channel at the back. To work properly, the rectangular box, with the narrower end facing downwards, needs to be floating at the top of that channel. Apparently it's a magnet which signals the circuitry that the water tank is full. Make sure it's floating to the cap of the channel. If not, you can get a replacement one from Gaggia.
May 29, 2009 | Gaggia Titanium Espresso Machine
Fill watertank
float valve stuck. try unplugging and then empty tank.check to see that nothing is visable in water reserve. fill water tank to full and then plug unit back in. hope this solves your problem
Nov 16, 2007 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
50 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
