Keylock showing on player...cant turn off...lost remote. What can we do?
2 Suggested Answers
SOURCE: how do you turn off keylock
Power off your display monitor then hold down the down arrow key on the monitor at the same time you power on the monitor. This should unlock the monitor keylock alshsh@epix.net
Posted on Aug 23, 2007
Keylock - how to remove without remote
Without a remote control, you can't unlock it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 04, 2014 | Televison & Video
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
Turning off the keylock function
What make and model television?
Jun 04, 2013 | Televison & Video
Keylock no remote
Hello
It will be very difficult to get the set out of keylock, without its original remote control.
Jan 02, 2012 | Emerson Dora The Explorer DVD Player
Control panel key locked and remote lost
Hello
To relsese the key lock, set keylock of OFF, using remote control.
Pressing the [RETURN] button on the porjector for 10 seconds will release the 'key lock'. OK.
Nov 15, 2011 | Toshiba TDP EX20 Projector
Missing remote control and projector keylock is on
I think you need remote for above said process.
Get original Sharp remote for XG-P10XU from Sharp Accessories.
Nov 10, 2008 | Sharp Notevision XG-P10XU Multimedia...
Buttons on front console no longer work.
time to upgrade not even worth it or to find parts sound like bad controller old ok samsung upconverting one 89 bucks circuit city k betifull picture thx nick
Feb 08, 2008 | Memorex MVD2027 DVD Player
How do you turn off keylock
Mar 20, 2007 | Kogi L7CH Monitor
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
