How can i fix the tv to turn off and on with the power button in the tv. i believe it is stuck in the demo mood. do not have original remote
  • deton8 von Splosion Dec 27, 2016
    Hi Richard Peters, If you don't put down a make & model... I'm quite confident your question will never get a second chance...
    EDIT it... pretty please
  • 1694 Answers
SOURCE: Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Posted on Nov 12, 2007
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
  • 8596 Answers
SOURCE: Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Posted on Nov 25, 2008
  • 2992 Answers
SOURCE: the power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Posted on Apr 27, 2009
I had the same problem with my TV, This is the way i fixed the problem i took a hammer and banged on the menu button a few times and know the tv works great!!!. Little weird huh:)
Posted on Jun 16, 2009
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Toshiba 32A42A - Menu options pop up all by themself, and the TV is making its own choices. Can this be fixed or do I call a Preist for an exercism or just get rid of it ?
I had the exact same problem yesterday. It took me 1 hour and 45 minutes to find a solution. Here is the solution: It is not a stuck button or the television being 'posessed' that is resulting in the menu cycling. It is the fact that the television is in the DEMO mode. I was able to read the manual for this television online at the Toshiba website. On page 30 it states 'To stop the DEMO mode press 'recall', ''exit', or 'power'. Unfortunately the 'recall', and 'exit' button are on the original remote which I no longer have. The power button on my model is broken. I use the cable box to 'turn on the television'. In reality, the TV is never off, it is just showing a black screen when the cable box and DVD player is off. I suspect this defect in the power button has occured on other TV's experiencing this problem. I was able to push the broken power button to the inside and side of the television casing exposing a round circle that the power button pushes when the power button is not broken. I pushed this small circle to turn the television off. After about 5 seconds I pushed the button again and the television went on without the annoying menu popping up. Just unplugging the television and plugging the television back in does not work. You need to be able to push the power button, or one of the other 2 buttons on the remote previously mentioned.
Also on page 30 it explains how to activate the DEMO mode. It's not too hard to accidentally do, especially when you have kids pushing buttons haphazardly.
I hope this helps someone outthere in cyberspace! Kevin
Sep 20, 2010 | Toshiba Televison & Video
LG Model LHT754 stuck in demo mode
press power button on tv,then scroll right to take it back to tv
Jun 30, 2017 | Audio Players & Recorders
Magnavox model# 19e604-00aa stuck in demo mode
Press +vol and -vol buttons on the tv at same time.
Jan 23, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Demo mode wont shut off
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
May 21, 2007 | Toshiba 32A33 32" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
TV Stuck in Demo mode
No sorry your going to need to get an original replacement, or maybe you can borrow one from someone for a short time.. Please rate this answer
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
I have this problem starting today. Unfortunately, others who have fixed it have done the following.
* Unplug TV for hours and it worked
* Buying manual switch to the outlet or surge protector and switch power off that way.
It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
Sep 27, 2006 | Hitachi 46F510 46" Projection HDTV
My 19" Magnavox won't come on.
LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
Sep 09, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
