My Ready Hedger Model RH 36. Blades don't activate, but the motor runs. Is there any gears broken?
3 Suggested Answers
SOURCE: XF50D motor won't turn shredder blades
Call ATIVIA # 877 777 4357 fax 866 765 0063 and they can help you. I GONNA GET BACK MY $$$$$$$$ .
Posted on Jan 12, 2009
SOURCE: Gear has broken on the mill of my Moulinex
great stuff
Posted on Apr 13, 2010
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
We have a model 2602 that jammed pretty badly. After unplugging we pulled out all the paper we could from both top and bottom and turned it back on. Now the motor runs but will not pull paper through. Is...
Check to see if both the upper and lower blades are turning. If the motor is running and the blades are not turning, then it is probably just a broken gear.
Feb 17, 2011 | Destroyit 2602 Shredder
Blades are stuck... Motor is running but blades aren't spinning.. Please help?
If motor is running but cutting blades are not turning then most likely you have a damaged/broken gear inside. You will have to open it up to see which gear then contact manufacturer for parts assistance.
Jan 14, 2011 | Martin Yale 1000 (Cross-Cut) Shredder
Royal Shredder 1200MX model Motor is running but not rotating blades to engage cutting fed paper
If the motor is running but the cutting blades are not turning then you have likely lost a gear/ or the teeth off a gear inside. You will have to open it up to find out which gear/gears are broken then you can contact Royal at 1-800-524-0799 for parts pricing and assistance.
Dec 29, 2010 | Office Equipment & Supplies
The motor runs but will not take paper and shred it. Embassey model pape shredder.
If the motor runs but the cutting blades are not turning then you have probably broken a gear or teeth on a gear up the top to verify.
Jun 16, 2010 | Office Equipment & Supplies
The mower starts, runs fine with brake depressed. When put in gear or blades activated stalls out. Possibly grounding itself out. where do I look either a short or problem?
This is a symptom of the seat safety switch not working. Tilt up the seat, check the connection to the switch and also check the wires (pinched, broken?). The switch could be bad, or the mounting could have broken.
Jun 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wiper blade motor runs but blades do not work
you have broken the gears in wiper transmission
Feb 15, 2010 | 1997 Nissan Maxima
Motor sounds like its running, but the blades
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Feb 02, 2010 | Krups KB720 5 Speed Blender
Durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
Jun 19, 2009 | Fellowes PS60C-2 Shredder
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
55 people viewed this question
