Question about Garden
My Hedger Motor Runs but the blades don't cut. some times thy run when I turn side ways.
  • 3 Answers
SOURCE: Motor runs blades not turn
Sorry about that, there is no gears for that machnie. Have a great day!
Posted on May 09, 2008
SOURCE: The blade/motor does not run, it only does run once
same thing happened to mine it was a short in the switch (replace switch) make sure to take note of which wire goes to each terminal before replacing
Posted on May 13, 2008
  • 63 Answers
SOURCE: my hedger turns off when I turn it side-ways to
The problem with Ryobi trimmers is the siting of the fuel outlet pipe the trimmes has to be full of fuel at all times
Posted on Jul 24, 2010
  • 153 Answers
SOURCE: my stand mixer's motor runs
Get a copy of the Repair Part List for your model at
Download a Copy of the Kitchenaid Service manual.
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
Posted on Aug 04, 2011
  • 6468 Answers
SOURCE: ariens ezr 1742 blades stopped while mowing, belts is good, blades turn freely, motor runs and machine moves
are you getting power to the electric clutch?
Posted on May 21, 2012
Delta 36-600 table saw new belt run's and sounds great, BUT wont cut butter?? Any help would be great thanks. Oh could it be brushes?? Cheers Matt Blade is in the right way,Delta 36600 have brushes.
Not to insult your intelligence, check the blade direction. Looking at the tablesaw from the left side, the blade should be turning clockwise and the teeth cutting downward. Also the teeth should be very sharp. Typically a belt run tablesaw doesn't use brushes but a capacitor to start rotation. You didn't mention if the blade turns when started. Since you mentioned it sounds good when started I'd rule out the motor. Some saw blades have an arrow to indicate direction. Hope this helps. Good luck.
Oct 28, 2017 | Vacuums
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
Target wetsaw starts and runs fine. Half way through the tile the blade binds and the motor bogs down which trips the breaker. It does it every cut now. Never had an issue before. Tightened the belt, still...
First thing I would check is that the table is square to the blade. If the back edge of the table that pushes the tile through the blade isn't perpendicular to the blade the cut will start fine but as you go through the tile the table will be pushing the tile into the side of the blade and cause a huge amount of friction, making the motor work harder and eventually pop the circuit breaker.
Jan 21, 2011 | Husqvarna Saws
My hedger turns off when I turn it side-ways to
Jul 11, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
My lawnboy lawn mower Runs Rough & Will Not Accelerate... What can I do to fix that?????
Your keyway might be cut. The keyway is the timing of your motor. If its cut, the motor will either run rough or not at all. If keyway is ok, check your blade for balance. Take blade off machine, hang on a nail straight across, if it tips either way, its out of balance. Have it rebalanced or replaced.
Jul 08, 2010 | Toro Lawn Boy Self Propelled CARB Walk...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
Blade won't turn in Cuisinart Duo Blender -- not motor
You have to unscrew and disassemble the blades - pretty easy, just take two rags and grab the blades with one (so you don't cut yourself), and then turn the rubber piece on the other side COUNTER CLOCKWISE, opposite of what you would do to loosen. the rod that runs in the middle that's connected to the blades on mine was all corroded, so I sprayed it down with WD-40, took my Dremel to it and smoothed out the corrosion, added some fresh grease ($2 tube goes a long way), washed the other parts with some Dawn and dried completely, reassembled and it runs much better! Not sure how long it will last, but I have a feeling that one time I ran the blender for a long time instead of pulsing, and the grease that came with it couldn't handle the heat from it turning so long. Anyway good luck!
Jun 25, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Blade does not turn
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Feb 11, 2009 | Craftsman 10" Table Saw
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
