Question about Ovens
Got a very old blodget oven was very good dont want to loose it so i need price for a new burners and the the base plates inside
Http://www.exclusiveugg.com
welcome to visit.many new boots and handbags.
dont lose time! u will like it!
Posted on Jan 08, 2010
    Scholar:
  • 81 Answers
I'll need a model # & serial # from the oven, if you cant find it behind the control panel inside left then, remove the bottom panel where the burners are & look inside it. Last resort, send pictures of parts needed and I will match them up with my parts manual. capt_rick1912@yahoo.com
Posted on Jul 25, 2009
I just bought a about 35year old house it has a chef contessa deluxe gas freestanding oven and warmer i don't know the model no can you help i need a manual and parts
Hello Helen, most model number labels can be found either under the cook-top surface burners; on the side of the oven unit; or in the back near the vent. Other places to consider, behind the oven door jamb along the top or side edges. If your particular stove unit has a kick plate, you may find the oven's schematic attached to the inside of the kick plate with may contain the technical data to your unit. Hope this helps.
Feb 12, 2017 | Ovens
I cooked something for 40min as it said and at the end it was raw, I had to pur it on further 40 min this is a conventional oven
It could be your oven isn't as hot as you set it. Get a thermometer and check it. It could be the "something" you cooked was larger than the recipe was expecting... It's cooking, you have to adjust. It could even be your altitude above sea level. Higher, water boils at a lower temp, things take longer to cook.
May 15, 2015 | Ovens
Blodget zephaire commercial oven not turning on when closing door
open burner panel and checked for door switch first ....good luck
Aug 30, 2014 | Blodgett DFG-100 Gas Single Oven
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Front big burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 10, 2009 | GE Profile JSP47 Electric Single Oven
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Front right burner on GE glass top range not working
Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
Hotpoint built in oven top grill element renewal
yes they are - two nuts on posts that stick out from the base plate plus one screw inside oven opposite the base plate
Sep 09, 2008 | Hotpoint Ovens
Blodget Oven
did they sell you a broken one?
Jul 05, 2008 | Blodgett DFG-100 Gas Single Oven
Lincoln Impenger 1100
hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Apr 27, 2008 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
79 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
