Question about Samsung Dishwashers
We just got a Samsung Chef water wall dishwasher. The first time it was turned on it has an error code LC. Called Samsung had no luck.Have researched videos and online. Need answers on how to fix?
3 Suggested Answers
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
mjbr122
  • 4 Answers
SOURCE: How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Posted on Dec 19, 2014
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Nov 14, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
Error code "6E2". Panel is frozen. Turn off from
i got 3 times this code in less than 2 years and motherboard has to replace.technician said samsung dishwashers got bad system.
Nov 17, 2010 | Samsung DMR78AHS Builtin Dishwasher
My Samsung dishwasher has a error code 4E after i start it up could you please let met know what this means thanks
Most common error codes that are caused by installation errors are:
  • 4E. If your dishwasher is displaying error code 4E, it can be caused by the water supply valve. The water supply valve may be closed, or not fully open. Most water supply valves are not frequently opened or closed. Because of this, they may be difficult to turn. To make sure this is not your issue, turn the supply valve to the fully closed position, clockwise, and then turn the valve to the fully open position, counterclockwise.
    • Check your water pressure. Your dishwasher requires a minimum of 20 psi and a maximum of 120 psi.
    • Water filtration info.
Nov 14, 2010 | Samsung DMR57LF Builtin Dishwasher
I HAVE THE SAMSUNG DISHWASHER dms300trs AND IT SHOWS F3 ERROR ???
Have the same problem with brand new, unused DMS500TR dishwasher. Rang Samsung, they said F3 is a water leak error.
Aug 19, 2010 | Dishwashers
LE Code Help - DMR57 Series
I had the same problem. On the bottom of the unit is a tray the catches any water that leaks from the tub. In the tray is a sensor that shuts off the unit and water if it get wet. Take the tray off and see if water is in it. If so, you have a leak somewhere. You might be able to dry off the sensor and get it to work but if you have a leak, you want to know. Best way to check is put the dishwasher up on two milk crates, leave the tray off and turn it on the rinse cycle and see if any water drips.
On my first unit, the rubber seal was installed wrong at the factory. They replaced the seal, but the error came up again. When checked out, the tub was leaking too. The dishwasher was replaced with another one. After one wash, the same problem occurred. LE error. I took it back and got a different Samsung model. It just stopped working after only two weeks. Evidently the touch pad sensors are bad because it will not turn on. Needless to say I'm getting tired of installing dishwashers. I think I will go for a different brand.
Feb 10, 2009 | Samsung 24 in. DB5710DT Stainless Steel...
Fisher & Paykel Dishwasher
If the machine has stopped and still has water in it, the drain pump is jammed. The pump is situated under the machine on the right hand side and can be accessed if you tilt the machine back against a wall. Try turning the motor fan by hand. Sometimes it will clear any foreign matter caught in the pump. If still jammed, remove pump by switching the machine off at the wall and pulling out the plug. Remove the wiring harness from the pump and turn it clockwise while releasing the white plastic clip which holds it in place and keeps it from turning on its own.
Oct 03, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Dishwashers Logo
47 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
