Question about Jensen Audio Players & Recorders
I need manual for Jensen SRWS 1000 AM/FM Weather Radio
Weather radio manual
Aug 30, 2013 | Audio Players & Recorders
Fips codes
FIPS are 5 digit codes..the 1st two codes are for the state: the last three are for the county. This link allows you to find both state and county for your area:
Apr 21, 2013 | Midland Radio Midland WR11 Desktop Alarm...
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod .
Dec 28, 2010 | Jensen VM9510 Car DVD Player
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
No more TV on Sony TV/weather/fm/am walkman srf-m37v.
There's nothing you can do. With the switch to digital broadcasting, the sound isn't on the same frequencies it used to be so this radio can't pick it up. Right now, nobody's offering a digital receiver for the sound. All your radio is good for now is the regular radio and weather broadcasts.
Jun 16, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Jensen JCR-550 manual
Get it on internet,type and download the manual is free.
Dec 22, 2008 | Jensen JCR-550 Clock Radio
Here is the manual..from some obscure Black & Decker/DeWalt (the new owner of Vector) site:
May 10, 2008 | Vector VEC438 AM/FM/Weather Radio
Not recieving fm radio stations
if you can get am stations the problem is in the radio's tuner if you cannot get am stations either your antenna is bad, if this helps you please give me a good rating if not please e-mail me at
respectfully, m.merle
Apr 17, 2008 | Jensen CDH-1000 CD Player
Weather radio
Can find the service manual at for a small fee you can download the manual.
Feb 18, 2008 | Emerson RP6247S FM/Weather/AM/TV Radio
What you want to do is set your radio to the proper S.A.M.E. (Specific Area Message Encoding) code for your county. You will find this information on the NOAA website which can be found at Find your state and it will list S.A.M.E. numbers by county.
Setting the code:
1. Push the CNTY/CH button on your radio. 4th button from the top /2nd up from bottom. This will prompt you to set the county.
2. Push the SET button. Button at bottom right. This will prompt the screen to show a set of 6 numbers flashing with the first number.
3. Under the screen you will see a set of 5 numbers and a 5+ with its corresponding button underneath. Use these for setting the code. For numbers above 5 use the 5+ button (e.g. 7 = 5+2). You will be able to set your radio for 10 different S.A.M.E. if needed. To do this you scroll through each S.A.M.E. number by pushing the CNTY/CH button.
4. After you set the S.A.M.E. number, push SET again to prompt you for the proper channel. The channels are A - G. You will want to have your radio on for this to be able to find the clearest channel. Turn your radio on and push the NOAA button under the screen. Push the CNTY/CH button till you get prompted for the SET CHANNEL. Push the SET button and the channel will blink. To scroll through use the TUN- OR TUN+ buttons and find the clearest channel.
You should be all set! Hope this was helpful.
Feb 04, 2007 | Jensen SRWS-1000 AM/FM/Weather Radio
Open Questions:
61 people viewed this question
Top Jensen Audio Players & Recorders Experts
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
