How long should charging take from wall outlet? Ours has taken all day.
    Top Expert:
  • Computers & ... Master
  • 24,808 Answers
Charging what and with what? Have you read the instructions that came with your new machine or if old, the battery may be exhausted.
Posted on Dec 27, 2016
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
I have a durabrand portable dvd player and I can not get the battery to recharge. I have unplugged it from the DC in jack and the cord from the wall. Reinserted the battery, then inserted the AC adaptor...
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like,, to buy a new litium battery or a compatible one.
Aug 25, 2011 | Durabrand PDV-709
Hi, I'm having trouble charging my Nokia 6300i with a USB cord into a wall outlet with a charger similar to the apple wall charger. I haven't used the phone in over a year and i'm not sure...
Good day!!!
if you phone is not used over a years that can cause a lot of problem like the battery is gone or its drain because it not used for a long time..
I think that is your problem..try to replaced the battery to fix your problem..
thank you for using fixya...
have a nice day!!!
Jun 30, 2011 | Cell Phones
No power. Will not turn on
Not intended to offend;
1. If using A/C (house electrical power), please check if electrical wall outlet is active. Attempt to plug-in another electrical device such as a lamp, clock, radio, etc.. If the electrical wall outlet has top and bottom plugs, try the top and then the bottom plug to see which one works. Sometimes, the top outlet will not work, yet the bottom outlet does work. The wall outlet should be replaced by qualified technician.
2. If both outlets do NOT work, and the outlet is GFCI breaker protected, maybe pressing the RESET switch on the outlet will power-up the outlet.
3. If the outlet is NOT GFCI breaker protected, check your electrical fuse box for a tripped fuse. Sometimes, a tripped fuse is NOT visible. May have to trip the specific fuse or all fuses to off, then back on. Recheck the wall outlet.
4. Once your know the outlet is live, check the power cord (a/c adapter for laptops) to make sure they are securely plugged-in to both the wall outlet AND the PC or Laptop.
Will need more information once the above steps are taken:
Is it a Desktop or Laptop?
Make and Model (if known)?
Any lights (glowing) on the desktop or laptop?
Any lights on the A/C adapter if its a laptop?
Mar 30, 2011 | Computers & Internet
Is mp3 player is chargeable ???how to charge
It depends on what type of mp3 player you have. Most now a days come with a USB charger that you can plug into your computer to charge/sync data. If you're looking for something to plug into the wall, visit a local RadioShack or BestBuy and look for a USB Power Outlet.
Mar 22, 2011 | Audio Players & Recorders
My son bought this for me, and he has taken the user manual (if there was one) to New Zealand with him - he lives there. Can I obtain another manual? I don't know a) how to charge the battery and b)...
Here is your Owner's Manual:
To Charge Your Nuvi:
  • Connect the vehicle power cable to the mini-USB connector on your nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for the nuvi to charge.
  • Connect an AC adapter (optional accessory) to the nuvi and a wall outlet.
  • Connect your nuvi to a computer using a USB cable. The USB cable is included with some Nuvi packages. The computer must be on for the nuvi to charge.
Mar 11, 2011 | Garmin Nuvi 265W GPS Receiver
I have a one outlet utilitech timer and forgot how to set it
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
After I charge my phone, it doesn't come on..
Is there any water damage to the phone? Does it power up when it plugged into the wall?
Try taking the battery out and plugging it in, does the unit power up? If it does not try another wall outlet or power adapter. If another wall outlet and power adapter still does not work, the phone will need to be taken in to service or replaced.
Oct 16, 2009 | Samsung Eternity Cell Phone
Computers & Internet Logo
David Payne
David Payne
