Stuck in safe mode factory reset and still says safe mode how do we get it out of safe mode
2 Suggested Answers
jonsnell4
  • 21272 Answers
SOURCE: I did all the necessary steps to get out of safe mode including factory reset but it is still in safe mode... how can I fix this?
File errors, could be hdd issues.
Posted on Mar 24, 2015
Gccant get my sa?fe mode off. My rca andriod tablet
How do I get my Android tablet out of safe mode?
Use the following steps to get out of safe mode.
  1. Restart your device by holding the power button, then tap Power off.
  2. Tap Ok to confirm.
  3. Power the device on. Your tablet should now be out of safe mode.
If the device is still in safe mode use one of the following methods.
  • Uninstall the last application you installed:
    1. From the Apps menu, tap on Settings.
    2. Tap on the app and then tap on Uninstall.
    3. Restart your device.
Perform a factory data reset:
  1. From the Apps menu, tap on Settings, and then tap Backup & reset.
  2. Tap on Factory Data Reset, and then tap Reset Tablet.
  3. Tap Erase Everything to format your tablet back to factory default configuration.
Source: http://packard-bell-uk.custhelp.com/app/answers/detail/a_id/27146
Hope this helps!
Jun 26, 2017 | RCA Computers & Internet
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Apr 20, 2016 | Nextbook Tablets & eReaders
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
How do I get my LG 7.0 tablet out of safe mode?
Get an Android Tablet out of safe mode
    1.Restart your device by holding the power button, then tap Power off.
    2.Tap Ok to confirm.
    3.Power the device on. Your tablet should now be out of safe mode. If the device is still in safe mode use one of the following methods.
      ·Uninstall the last application you installed:
      1.From the Apps menu, tap on Settings.
      2.Tap on the app and then tap on uninstall.
      3.Restart your device.
      ·Perform a factory data reset:
      1.From the Apps menu, tap on settings, and then tap backup and reset.
      2.Tap on factory data reset, and then tap reset tablet
      3.Tap erase everything to format your tablet back to factory default configuration.
Nov 21, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
How do I get my nextbook tablet out of safe mode?
Nov 04, 2015 | Nextbook Tablets & eReaders
Nexus seven 2012 stuck in safe mode
go to settings and look for reset to factory!!!
Jan 10, 2014 | Computers & Internet
My lg optimus s is stuck on safe mode how do I get it back to normal
Factory reset should be the last thing you try. Dont take this the wrong way, (I just dont know what you have done, why you are in safe mode, etc), but have you tried just re booting it, ie shutting it off and turning it back on normally? If that doesnt do it, pull the battery out, wait about five minutes, then put it back in and turn it on again.
Mar 09, 2011 | Cell Phones
I have safe mode on my phone and i cant turn it off cant use apps i want how do i turn it off? i have a mytouch 4g i factory reseted and rebooted it doesnt work help
Please check your menu key and see if it is stuck. For your phone to boot into safe mode, the menu key needs to be held at power on, so if after turning it off and doing a factory reset you are still in safe mode, then your menu key stuck. I have heard of the g1 having issues with the menu key getting stuck and a replacement is needed. How old is your phone? Are you still under warranty with tmobile? Let me know if you have any other questions.
Mar 01, 2011 | Cell Phones
Computers & Internet Logo
David Payne
David Payne
