Question about Canon Cameras
Quick control dial on a canon camera stopped working
  • kakima Dec 27, 2016
    Hi Richard Kam, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What model Canon camera?
  • Richard Kam Dec 27, 2016
    Hi Kakima, thanks very much indeed, its an EOS 1ds Mark 3,much appreciated..the button right in the middle does work, the dial doesn't..
How to restore factory settings
To restore your camera settings to the factory default: Press the Menu button. Use the Multi-controller to navigate to the CameraSettings 4 tab. Use the Multi-controller or the Quick Control dial to highlight Clear All Camera Settings and then press Set.
Oct 04, 2015 | Canon PowerShot A410 Digital Camera
My cannon g12 camera takes over exposed photographs. he shutter is working well. so, help me.
Check your Exposure Compensation Dial. In shooting modes where exposure compensation is allowed, this dial can be set to decrease or increase the brightness of the image in 1/3-stop increments across a range of -2 to 2. You use this control to override the camera's automatic exposure settings to get a slightly darker or lighter image. It should be set to 0.
Mar 04, 2012 | Canon G12 Digital Camera
The language on my Canon EOS 5D Mark II is all in Japanese. Is there any way to change it to English? Thanks
Follow the correct instructions below based on the diagram to change the language of Canon EOS 5D Mark II from Japanese to English;
1.Press the MENU button.Different tabs are displayed on top of the screen as shown below.
2.Turn the Main Dial to select the tinualbinale_33.png Setup Tab ( The one with two dots and a spanner) on top of the screen.
3.Under this tab Turn the Quick Control Dial to select [Language] ( the third item from the top ) and press the SET button.
4.To select the desired language use Main Dial or Quick Control Dial (The current setting is indicated in Blue) and Press the SET button.
5.The desired language is set.
Thanks for choosing Fixya
Jun 20, 2011 | Canon EOS 5D Mark II Digital Camera
I am shooting on Manual (M) on the dial. My f-stop is stuck. Why would that be? Did I cripple it by tweaking the wrong setting? Help!
No I doubt your crippled it but you might have neglected to turn the "Quick Control Dial" on here is a diagram of the little mark to set the switch to.
Diagram
Feb 06, 2011 | Canon EOS 50D 15.1MP Digital SLR Camera...
The rear control dial on my eos1n does not work
The switch to the right of the Quick control dial is the on off switch for that dial, to the lower left is the camera on/off switch. If the camera was left in the "A" position the LCD panel on the top will drain the battery always set the camera to the "L" position when not in use
Nov 25, 2010 | Canon EOS-1N 35mm SLR Camera
Canon 40D camera On P mode it is - 2 stops I can't find the setting to take it back to 0 and my pictures are underexposed.
When you turn on the camera, there's an option to turn the switch beyond "On", indicated by an angled line. Move your power selector switch there. Then half-trigger a scene and turn the Quick Control dial behind the camera to adjust the Exposure Compensation. Note: Being in "On" mode doesn't enable exposure compensation, leaving the settings stuck at previous.
Apr 19, 2010 | Canon EOS 40D Digital SLR Camera Digital...
How do I change the aperature in the manual mode. As I change the shutter speed using the top dial, that works fine however, I'm having trouble using the dial on the back to change the aperature. What...
Make sure that the power switch is in the correct position.
It actually has three positions:
  • Off
  • On (with quick control dial disabled!)
  • Third position (quick control dial enabled!)
So, when the power switch is in the middle position (ON), the rear control dial is disabled in order to save you from inadvertently changing the setting, when you are wearing the camera on a neck strap.
So be sure to put it in the third position.
Mar 17, 2010 | Canon EOS 40D Digital Camera
How do I change the f stops on a Canon powershot sx100
Set the mode dial on the top to Av.
Use the control dial on the back to change the aperture value.
This is shown at the bottom center of the LCD.
Shoot.
Set the mode dial to auto or whatever when you have finished.
Hope this helps.
Feb 05, 2010 | Canon PowerShot A75 Digital Camera
Manual focus points 40D
Try checking C.Fn III, 3: AF point selection method. Yours might still be on option 2.
0: Normal - Works by pressing the AF Point button and then the Multi-controller.
1: Multi-controller direct - Press the multi-controller to directly select an AF point (without first having to press the AF Point button). Pressing the AF button reinstates all AF points for auto AF point selection.
2: Quick Control Dial direct - turn the Quick Control Dial to select AF points. In this mode, AF points will not be displayed on the LCD panel.
Jul 18, 2008 | Canon EOS 40D Digital Camera
Canon 40D i do not know how to turn on my lcd screen so i can see through it while shooting my image, is it possible?
Prepare to Live view shooting:
1. Set the lens focus mode (on the side of the lens) switch to <MF>
2. Set the shooting mode to a Creative Zone mode
3. In menu under the settings tab, select Live View function settings and then press <SET>
4. Turn with quick control dial to select Live View shoot and press <SET>
5. Turn with the control dial to select Enable and press <SET>
With the camera ready to shoot, press <SET> - image will appear on the screen in real-time
I hope this answered your question
May 30, 2008 | Canon EOS 40D Digital Camera
Cameras Logo
136 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
