Question about Maytag Dryers
Why does my Maytag dryer not heat? Model # is MGDC500VW0
I have replaced all the Electrical sensors and all of the gas components. The exhaust vent is clear. I did not replace the timer because it still advances. I replaced the igniter and the flame sensor. The gas components includes the valves in the dryer but not the shut off valve on the supply line, but this valve is fine. Could the timer be the problem or would it be something else?
  • Maytag Master
  • 2,374 Answers
Did you replace the igniter?
Posted on Dec 27, 2016
Testimonial: "I replaced the Igniter a flame sensor"
  • robert Dec 27, 2016
    I'm sorry I somehow missed your complete first text. So the igniter was a poor question. And when you say all gas components that includes the gas valves?
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
The dryer is not getting hot
check the exhaust vents thoroughly. If full of lint the moister sensor will keep the burner off at all times you use this dryer. If the vents are clean and it still will not heat replace the moister sensor and replace the spark ignitor at the same time
May 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Mayag Nepute gas dryer (MDG9700AWW) starts drying and them continues running with no heat. There is a gas smell exhausting from the vent. I have already clean the vent and exhaust system internally and...
I got the same problem. A technian came over and checked, he told me that it is gas valve assembly problem. the gas valve needs to be replaced. it is very costly, the part is $253
Mar 12, 2010 | Maytag Dryers
Dryer runs, but no heat , gas dryer and everything is reasonbly clean. It is a maytag model#mdg7400aww
Check the following components to combat this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 16, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Gas shuts off/flame off w/in minutes of starting maytag gas dryer
If you did all the things listed, there are only 2 left that will cause the problem. The cycle thermostat located on the exhaust vent and possibly poor airflow. Remove the connecting vent from the rear and try a timed load. If it works repair the vent exhaust problem. Most cycle thermostats include a thermister that could also be defective causing the short cycle. The flame sensor and gas valve coils would have been the number 1 diagnosis. I would need a model number to more specific.
Jun 14, 2009 | Maytag Dryers
Maytag gas dryer - model unknown - gas wont stay lit
Yes does sound like blockage in the exhaust vent causing the high limit switch to stop the dryer.
Mar 26, 2009 | LG DLG5932W Gas Dryer
Maytag Atlantis Dryer not heating up
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Aug 10, 2017 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer is fickle!
First thing is to check that the vent tubing both inside the back of the dryer [ the exhaust pipe that is attached inside the dryer ] and the tubing that vents it outside the house are not plugged by lint or ? if it is all clear you have an electrical component problem such as a sensor or valve.Unfortunately you will need someone qualified to diagnose and fix this type of problem.Good wishes for you.Stephen
May 04, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
57 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
