Question about Proscan Televison & Video
Could I get the code fo a proscan tv with th g e remote
    Top Expert:
  • Proscan Master
  • 75,471 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts
Posted on Dec 27, 2016
SOURCE: Proscan TV Manual
I have a Proscan model # PS36800HRJX1 and having a hard time putting it on DVD mode to be able to play a movie. I just bought a remote for it and can't figure out what's the problem. How do I go about it?
Posted on May 24, 2008
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
SkyGuy08
  • 27 Answers
SOURCE: sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
  • 814 Answers
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
SOURCE: Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Posted on Jul 22, 2009
I need the codes for the 'Dish Network remote' for my ProScan PLDED3996A tv.
The codes are for the TV not the remote, it only stores them, the code is the same no matter the type of remote. The Proscan TV code is listed as 0047
Dec 15, 2016 | Proscan Televison & Video
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can't program a Direct TV remote for Proscan TV
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
May 16, 2009 | Proscan 32LA30Q Television
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan universal remote
Feb 17, 2009 | Proscan 32LA30Q Television
Remote Code
The code 11178 worked for us for our Comcast remote.
Lauren
Jan 13, 2008 | Proscan 26LA30Q 26 in. LCD Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
