Question about Kitchen Ranges
I have Marey NG water heater recently the flame is short so I can't get hot water? Thanks
All knobs are max but Flame is too short and when I turn gas to low it goes to off
    Top Expert:
  • Kitchen Ranges Master
  • 48,294 Answers
Call a gas fitter to check regulator operation
if on bottles , check fill level of the bottles as they may be nearly empty
Posted on Dec 27, 2016
2006 water heater. Is it only run on gas. How do i turn it on.
If it is a regular gas hot water heater You need to turn the knob on the gas valve to pilot. Depress and hold the knob down. while doing that press the green button on the side of the valve . you may have to repeat that a few times. that button makes a spark to light the pilot. You need to hold the knob down for about a minute more to let the thermocouple heat up and signal the gas valve that it has a flame. release the knob . if the pilot flame stays on ,turn the knob back to the on position. If that does not work repeat if still not working give more info. Make and model of heater
Feb 03, 2015 | Water Water Heaters
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
on Dec 20, 2016 | Cars & Trucks
Ignition problem
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Nov 30, 2014 | Marey Heater Corp Marey Natural Gas 2.0...
Rinnai R75LS error 12. I recently went to fill my bathtub and got nothing but cold water. After checking the hot water heater it was flashing 12. After looking at the book saw it meant flame failure. My...
You may have instant hots for the sinks, a small heater for each location which won't be on the tub. If there is a flame fail the hot water heater is not working. Check the flame sensor and ignitor.
Jan 07, 2014 | Water Heaters
Bosch 125b-ng water heather has low flame only
Did you check to make sure the shut off handle is on the on position?
Dec 19, 2012 | Bosch AquaStar Natural Gas Tankless Water...
I have Marey nat.gas.water heater (3 years old) now the flame goes on for a second and goes off ,pezo try to restarted but wont go back on ,any solutions ?? many thanks
Sounds like your thermocouple is shot.It's that
little tube that the pilot light heats up.I am
assuming that you have started this heater
before.The thermocouple has to stay a certain
temperature to keep the gas flowing.You can buy
universal thermocouple kits at your local
hardware store.Make sure gas is turned
off.Loosen the coupling nut on the outside of
the tank then remove the tin and remove the
heating part.The whole thing is a small 1/8
tube.Bend new one like the old one and put it
back in place.If the kit has yellow Teflon tape
wrap the threads on the coupling and
tighten.Turn the gas back on and test for leaks
with soapy water.Thanks for choosing
I always add this for your information. If this
is not the solution that you are looking for
please re post because when we pick a question
to answer FixYa takes it out of the questions.
May 22, 2011 | RTO Ng Gas Tankless Water Heater - By...
Pilot don't stay lit after the gas control knob is release.
The thermocouple is bad and you will have to replace it...
The thermocouple is the thing that sticks up in the flame to sense that the flame is on... if it goes bad the pilot flame will not stay lit when you release the button...
Dec 05, 2010 | Williams 3501922 (NG) Gas Compact Heater
It has soot build up and doesnt get hot
the soot build up is evidence of another problem. Your fuel air ration is messed up. Is it possible you are at a higher altitude than the water heater was set for? When a water heater is installed at an altitude higher than 2,000' the manifold pressure on the gas valve has to be turned down. if that isn't done your wh will overfire and burn a rich sooty flame. You would expect to see a yellow flame rather than the ideal blue flame with yellow tips.
If this sounds like your problem then you need a proffessional to service the wh and reset the manifold pressure to the value in the owners manual for the appropriate altitude.
Jun 30, 2010 | Bosch AquaStar 2400ES-NG
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
