Question about Dishwashers
Replace bottom door seal - Dishwashers
5 Suggested Answers
  • 3 Answers
SOURCE: whirlpool duet front loadsher leaks at the bottom of door. how do you replace the seal around the door
Hey Guys or Gals
The Whirlpool Duet Washer and why it Leak's. 1) Make sure the Boot(which is the black thing that hook's to your tub and your door) And the ring around it, is tight.Now this Ring,is a Metal Band that keeps the boot on the tub Tight .You can tighten it or loosen it..ifs its loose, then it will leak...Then, there's a Ring around the door as well, Both of these rings are hard to see..so make sure, your really looking good. Now what most people don't thing about is the Main Inlet Tube.On page 18 in the manual.on picture 3.5 it show this source of water that comes into the tub.,this Main Inlet Tube that connect to the Dispenser Assembly,will come loose and will Drip or at times Leak bad,To be able to understand where this is located. First 1) take of the top cover of the washer, 2) take off the front part that hold the door on.That means when you look at your Manual look to pages 31,32,33 and this will tell you how to take off the front of the washer,It's not that hard, to take off,just take your time..and have an extra pair of hands helping you, so it easier and faster.But once you get the front of the waster off,and yes that counts the Electronic display header,That's that button you push to run the washer,,it will pop off after you take a couple of screws out ,after you take the top of the was off..you see them. but back to the MAIN TUBE INLET, this will loosen and water will leak from this now when you replace the boot on this the tube will come loose when trying to put your ring around the boot,you cant tell that its loose becaue you cant see if after installing the boot,i know this dont make any since,but im sure it will if your start to tear it apart..and taking these steps to fix the leak. just make sure that you track the leak,to make sure that this is it...just make sure you take the steps to repair it ..if that means order a new piece then do it. But These Step Will Save you Lots of Time & Money if your Going to play someone to fix it...Here's the Link to the Manual,Just download it and go to the pages i put down ..Might have to copy and paste the address
.http://appliancejunk.com/forums/index.php?action=tpmod;dl=item43
Posted on Jan 14, 2008
SOURCE: door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Posted on Jul 02, 2009
SOURCE: Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Posted on May 08, 2010
  • 3247 Answers
SOURCE: Bosch SHU6802UC - I need
It is good to know you have managed to replace the control module. Not sure if you have seen this diagram. This helps identify the location of trims and screws that would be holding the door seal. it is item 4.
Hope this helps.
Posted on Nov 29, 2010
How to replace bottom door seal
Difficult job. It may be possible to take the door halves apart and get to the screws that hold that bottom door seal to the door, but in some cases, it is necessary to remove the door completely and take it apart to be able to replace that bottom door seal. In any event, it's probably best to call a professional dishwasher repairman and let him do the job.
Sep 24, 2014 | Dishwashers
Replace bottom seal hoover dishwasher
There's only 2 screws under the top where it screws to work top and 2 on the inside where there are 2 White plugs on either side. If the bottom door seal is leaking you don't have to pull it out just remove inner door and replace , bottom seal comes with the inner door not separate.
hope this will be helpfull to you.
Goodluck..................
Feb 02, 2011 | Hoover 24 in. HD73M Free-standing...
GE French Door PFS22MIS Door seals are torn at top of both doors. How difficult to replace?
use your model # to order new seals. they are easy to replace. Just grab an edge with your fingers and pull and the door seals will pull out of the groove they are in. to replace, start at the bottom center of each door pressing the seal into the groove. don't stretch the seal as you replace and it will fit perfectly.
Nov 29, 2010 | GE GBS22HCP Bottom Freezer Refrigerator
Kelly --
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
Door still leaks after replacing bottom seal
Dec 20, 2008 | KitchenAid KUDC25CH Dishwasher
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Water leaking out of bottom of door
There is a rubber seal that runs along the bottom of the door. If you carefully run your hand along there just to see if it is all even. Sometimes they get out of place and you can push it back and then closing the door it realigns itself and all is good. If the seal is damaged, you have to replace the door liner as the seal is attached.
Sgt 48
Oct 24, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
SERVICE FLASH
DW071
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Sep 18, 2007 | Dishwashers
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
