Question about Compaq C3 1000 3 In One All-In-One Thermal Printer
Lost my power suply, what voltige and polarity?
    President:
  • 1,566 Answers
You can consult the manual.
http://h10032.www1.hp.com/ctg/Manual/bpu80012.pdf
Posted on Jul 21, 2009
How to bypass secuity system in1998 park ave
you cannot simple ,call the dealer to re-programme it
Feb 22, 2016 | 1998 Buick Park Avenue
I have a Uniden TRU8885 - 3 Base, when I plug into power suply, it turn on, but after the base turn on and display the message welcome, the base turn off
buy higher capacity power adapter 9volts 1000mA capacity and use ensuring correct polarity, it will work. i had the problem and adopted this and this works ok. also ensure your handset battery is new and charged after installing the higher capacity power adapter. good luck. venkataramani
Aug 27, 2011 | Uniden TRU8885-2 Cordless Phone
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
Canon PM530 printer doesn't power on.
i think the power suply lost a lot of amperage so the printer need more amp
check the output of power suply or take a other wit a little more amp (no more voltage !!!!!!!!) look on adapter
Oct 18, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Lost ac/dc adapter
Hi, for a 12v 2 ampers device any universal laptop power suply can be used. They usually are tesignedfor about 2-4 ampers so it won't be a problem. All you have to ake soure is the correct polarity, and the changeable dc plug.
good luck.
Mar 20, 2009 | Kogi L7CH Monitor
Display problem
how many voltiges?
You said to ask. Are you getting a boot screen but no OS Screen? Check your video card and make sure it is in all the way. If on board video, get a cheap video card and try it.
May 26, 2008 | Computers & Internet
Acer AL1715 going on and off (LED blinking)
Hi maxwell,
Firstly check for the surrounding components like th coupling resistors for a short. Change them, then look for leaky diodes (a diode shows low resistance when connected to a multimeter with correct polarity and MUST show infinite i.e. NO resistance at all when polarity of the meter testprods are reversed) As for the deformed capacitor change it with similar type, voltage and size.
VERY IMPORTANT: Make sure you put in the new one back in the same polarity (since it is an electrolytic type capacitor from what you mentioned in your querry) elase the new one will explode if the polarity is wrong.
Better still, if you are not good at soldering components that are so closely attached on the circuit board, just give it to an authorised service center in your area.
May 04, 2008 | HP Pavilion F1703 17" LCD Monitor
Compaq C3 1000 3 In One All-In-One Thermal Printer Logo
57 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
