When it gets loaded how to restart FX10 again ? How to take precautions to prevent loading? How to grind hard and sticky stuffs ?
5 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: Loud sort of grinding noise
unplug dryer
front panel screws are mounted in the bend at the bottom of the panel, hidden from easy view by the bend.
  • may be torx secure screws, either cut a slot in the screw head and use a flat screwdriver, or buy a torx secure #2 bit at the local alltools
swing front panel up and forward, unplug door switch wires, set panel aside,
examine roller bearings,
drum felts,
belt tensioner
for wear
takes longer to type than to open the dryer
good luck
Posted on Aug 27, 2008
  • 409 Answers
SOURCE: Brown sticky spots
sounds like you have an oil leak from the motor/pump assembly. this should be covered under warranty by the mfg. have a technician replace the sump assembly.
Posted on Sep 13, 2008
SOURCE: Saved data not loading from hard drive for Resident Evil 5?
another way to cure the cash issue is to go into the system blade pick memory.press Y on either HDD or Mem unit then press x,x left bumper then right bumper,x,x
A blade will pop up saying this will perform maintenance on xbox 360 storage click yes and off you go.
However dont get excited as it may not cure the issue and I had to reformat the hard drive losing everything and it keeps happening.
Not a happy bunny but yes the system runs better
Posted on Nov 20, 2009
homedesigner
  • 583 Answers
SOURCE: I put a new Hard drive in my sony viao VGN-NR260E
You must partition the new hard drive, sometimes that step can be bypassed by just hitting Enter at the prompts. It has to be partitioned and then the partition has to be formatted through the Windows setup routine. By sure and partition it as a primary partition.
Posted on May 15, 2010
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Good luck.
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Will not go pass windows updates stage 3 keeps restarting
Probably a stuck update.
Restart in safe mode (F8) and click on My computer / Hard drive (right mouse click) Under properties, select tools/ check volume for errors, it will schedule a check, reboot and let it check the drive
If this fails, try using system restore to go back to a time before it was updated OR
If you can get into safe mode, review what has been installed recently and uninstall it.
Try updating again
Your antivirus may be preventing the update, yoou could TEMPORARILY disable this and see if that helps
Dec 31, 2010 | Acer Aspire 5920-6727 Notebook
Browsers on my computer are not loading pages fully. Sometimes I have to stop the loading and enter the address a second time to get it to load. Sometimes it grinds away so I stop it and refresh the page...
Okay a few things needed to be done!!
First clear your history, and go to tools, etc and make your browser clean it self upon each occasion of leaving or turning off so you wont pile up a bunch of info...
You also need to look and clean your hard drive and refrag it so as to clean it up!!!
(Do a cleaning of your hard disk each week if need be.)
If after all of that basic stuff Reinstall the newest version of that browser!!!
If you had like a virus like confliker from last year then you need to toatlly reformat that disk!! (After that bug it messes up your "IExplorer", which almost all browsers and other programs use in some way!!!
After you do all this you should be fine, this is basic maintenance each week or two if you and/or others use that computer!!!
Jan 03, 2010 | Mozilla Firefox
when u restart ur console keep the power button pressed down until the xbox360 boot screen then release it and push down again about 1min and restart it, this process clean your hard drive disk cache memory
xbox360 will become faster and more reliable after this
Jul 05, 2009 | Capcom Resident Evil 5 for Xbox 360
Sony 5 disc dvd player says c 31 00
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Mar 02, 2009 | Sony DAV-FX10 System
Tape residue on stainless steel
use lighter fluid like the stuff ZIPPO lighters use, rub softly using a soft cloth and the residue will come off. Leave the petrol on to soak and "melt" the sticky stuff for about 30secs-1minute before you start to wipe off.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Brown sticky spots
Aug 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Drivers for USB keyboard/mouse keep wanting to load after reboot
yes reinstall windows xp and a good antivirus and never update windows again. so take down that automatic updates stuff...
Mar 13, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
