Question about Water Filters & Coolers
Water cooler parts - Water Filters & Coolers
My sunbeam water cooler is steady dripping water what is the problem
Make sure the part is screwed in completely. I have expired model ylr2-5-87h3 and no one makes parts !!!!
May 30, 2014 | Tomlinson Sunbeam WATER COOLER FAUCET...
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
Can you patch a igloo cooler on the inside
Sure.......Clean it very good with thinner,then sand it,wipe it clean again then fiberglass or marine Tex it... You can find Marine Tex at your local parts place.[2 parts] is water Proof. DON"T use BONDO !!!!!!! It is not water proof.
Dec 24, 2009 | Igloo DOCKSIDE 25 Pier Fishing Cooler
Part needed
I finally found contact info for the maker and I have a number to call in Canada to order the part.
May 29, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Mar 26, 2009 | Avanti Hot and Cold Water Cooler
Water Dispenser hamilton Beach Water Cooler
my water cooler worked yesterday,today I get nothing from either the hot or cold water? Is this a simple fix or di I start with a new one?
Jun 02, 2008 | Hamilton Beach Water Cooler with Storage...
No Cold Water
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing.
May 27, 2008 | Hamilton Beach Water Cooler with Storage...
Water Filters & Coolers Logo
709 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
