Question about Fitbit Surge Large-Size Fitness Watch with Heart Rate Monitor
How do I change the clock time on my fit bit surge
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
1. Re-sync your Surge to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3. Make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit in your Bluetooth settings.
4. Try removing the Surge in the Fitbit app (should be under device settings) and then reconnecting it.
Hope that helps!
Posted on Oct 21, 2017
Cannot set time and date, how do i do that on fitbit
To change your clock to a 12 or 24 hour clock:
  1. Log into your fitbit.com dashboard and click the gear icon.
  2. Choose Settings > Personal Info.
  3. Under Advanced Settings, find Clock Display Time and select whether you want the time shown in 12-hour or 24-hour clock units.
  4. Click Submit and sync your tracker.
Aug 22, 2017 | Exercise & Fitness
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
We have had a power failure and the oven will not work unless the clock is reset but the manual instructions do not help as the knob does not change the time.
Every one of these things has a different method for changing the time/resetting the clock. You'll have to provide a make and model number.
May 29, 2015 | Ovens
I can't put an app on my cell; so how do I change the time to match the time-zone when I travel?
Unfortunately you have to use a smartphone which supports the app. I have however been able to connect my surge to my PC, but haven't tried to sync yet.
Apr 10, 2015 | Fitbit Surge Large-Size Fitness Watch with...
How to change the time
i hate to inform you - you are not sole owner of only one clock radio in the world... there is several thousand manufacturers, each of them make several models... first were made in the end of 1930's...
which one is yours? do use your brain a bit before you post the question, i promise - this does not hurt...
Mar 11, 2015 | Audio Players & Recorders
How do you set time on fitbit surge?
I downloaded the Fitbit app on my iPhone , followed the steps to pair with the surge, and voila, the correct time is picked up from the iPhone automatically.
Mar 06, 2015 | Fitbit Surge Large-Size Fitness Watch with...
I try to set the clock on the oven but pressing the CLOCK touch pad or the TIME-TEMP pad has no affect. It is completely nonresponsive.
It sound like the board is faulty, its quite common after power surges can cause damage to small circuit boards like clocks, I would recommend changing it as the clock will also provide timing for switch on at a set time cook for time as well.
http://dacor.com/Search.aspx?query=ECS227 Epicure Electric
Hope this is helpful
Regards
John
Oct 31, 2014 | Dacor ECS227 Epicure Electric Double Oven
When i start up my wii fit at say 6:00pm it says good morning
Change the clock time in the Wii system settings. The message is based on the systems clock time.
Jan 29, 2009 | Nintendo Wii Fit for Wii
Emerson Smartset CK1862 does not auto set the time
In this case, it is probably better to buy a new Clock/Radio. You should also try to figure out what caused the problem with the broken Clock/Radio. This will help you prevent it from happening to the new Clock/Radio. You probably need a surge protector. The surge protectors will help prevent the Clock/Radio for being damaged by transient voltage surges that happen during storms and power outages. Sorry this answer is so late in coming to you. Thank you for using FixYa and have a nice day.
Jan 25, 2009 | Emerson Smartset Clock Radio
Fitbit Surge Large-Size Fitness Watch with Heart Rate Monitor Logo
961 people viewed this question
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
