Question about Dryers
I am having trouble getting the remote to start up the fan and it does not seem to hold the settings Fan- CSF5247 Remote CFR251. John.
SOURCE: Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Posted on Dec 08, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 736 Answers
SOURCE: Hampton Bay Fan will not turn on.
on some you hold down a button on the remote control while you turn power on .. you keep the button pressed for maybe 20 seconds .. i dont remember what button but probably fan on or light on .. the receiver acquires the code from the remote .. if you still have trouble i can probably find the specific instructions ..
Posted on Jun 07, 2010
SOURCE: Hunter Fan problem
Thge black boxes are capacitors. One is a single and the other is a dual. Evidently the dual runs the two lower speeds and the single run the high speed.
You can test capacitors for basic operation with an analog voltmeter set to Ohms (Rx1 setting is best) by charging up the capacitor with the leadshooked up in one direction, and then reversing them to watch for the slight jump as the capacitor discharges back into the meter... note that this test only works with an analog meter and it must be set to ohms.
This is only a basic test for capacitors and will not indicate if it's withing specs, only that it basically works.
IMO, Hunter is known for having bad capacitors. I've just purchased two fans and already had to swap out the light kits, which contains the capacitors and switches, in one becuse of poor operation and excessive humming noise. since the other fans has the same componenets, other than being a different color, I also thought to try the light kit/capacitor assembly in the fan I've already installed before also installing the second fan.
Guess what, the other set of electircal components with the capacitors runs the fan slower and hums louder.
According to Hunter's web site, humming is a sign of poor engineering in ceiling fans (meaning a power hum rather than a hum from loose components) I agree and Lowes is about to get two Hunter fans back as my three cheapo fans that came with my house do not hum and also the one in my old house did not hum and moved more air.
Even the better capacitor set that I switched out still hums to some degree, so I'm climing Hunter's using **** components, probably becuse their chinese suppliers are screwing them and they're not bothering to keep up the quality control.
Posted on Jun 08, 2010
SOURCE: Power went out and now ceiling fan won't work
Before you try all of that try the on/off switch, I tried holding down the light switch on the remote and turning the on/off back and forth several times and then the light came on... it is very tricky, but I knew my battery was good, and the fan worked before the power went out and the dip switches did not need reset or changed. I tried many different combinations so I am not sure what tripped it up, but try that before changing anything or pulling the fan cover off. Best of Luck
Posted on Dec 12, 2012
Remote control codes for a hampton universal video and fan remote?
First of all start with the basics, Hampton remotes will only work with Hampton fans. If you have a different brand of fan then you need to get the complete remote kit with receiver unit. If you open up your remote, you will see a place you can select a code configuration. This should be set identical to the code configuration of the fan. You may have to take off the cover of the fan to see the code. Or keep changing the code configuration in the remote, until it starts working.
Jan 10, 2015 | Universal Televison & Video
Remote control not working
Dear Sir/madam,
Check these steps........
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, including this web site, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Converting to 3 speed:
One common question: My fan's remote is broken, can I just convert it to a 3 speed pullchain like other fans? Again unfortunately, if you have to ask the question, then chances are the answer is no. It can be done but there are no universal directions, it varies drastically from fan motor to fan motor, and requires a fair amount of technical and electronic skill. A few exceptions: If the fan has a "remote bypass" switch you can select it and then use a wall control (or pullchain if there is one attached to the fan). Or . . .
5. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
thanks
good luck
Aug 07, 2008 | Hampton Bay 52 In. San Lorenzo, Rustic...
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I have a hunter remote 29185 and it works fine, but throughout different times the light will come on and the fan will come on, it turns its self on and off. i tried to change the setting by flicting the...
Dont know if I can help, there should be a reset hole behind the control, stick a pin in to reset, if not hold the power button for about 30 seconds this should reset the unit, I beleive it is cycling through.
If none of this seems right do a google "image"search and you will be able to find manuals, instruction and trouble shooting for free, thats what I did , and thats why I'm here now trying to save time and headaches.
Feb 22, 2011 | Hunter 27187 Remote Control
Jun 05, 2010 | Hampton Bay 54 In. Dawson Ceiling Fan in...
Hunter ceilng fan remote trouble
just a shot in the dark here but those fans get real dirty real quick so have you tried cleaning the sensor cover on the fan?
Aug 21, 2009 | Hunter Dryers
I bought a house with hunter remote control 52" fans, and one doesn't work, I replaced the battery and still doesn't work. How can I verify the remote code is correct for this fan? The code on the fan is...
set the remote to match the fan code. be sure you have a good battery in the remote and in thereceiver which is in the dish at the ceiling holding the electrical wires
Jun 23, 2009 | Hunter 52" Ceiling Fan With Light And...
Im changing out a ceiling fan.
hook black to black white to white and the blue is a ground wire that you hook to the metal bracket that holds fan in cealing ( anywhere is fine just loosen a screw and place the wire anywhere!
Dec 09, 2008 | Dryers
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Jun 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dryers Logo
Top Dryers Experts
