Question about Dishwashers
My JDB1270AWY dishwasher doesn't get enough water to dissolve the soap or wash the dishes.
  • 32 Answers
SOURCE: Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Posted on Apr 07, 2008
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Posted on Aug 31, 2008
  • 423 Answers
SOURCE: Dishwasher wont dissolve soap and not washing properly
The make and model number can probably be found around the door edge (usually right side) If you can find it, post the make and mode # here.
Recommend you get a box of brand name detergent powder (like Electrosol or Cascade) and begin only using that. (Neve use gel or tablets) Cheap Cheap, generic detergent does not dissolve properly, leaves residue of its own and cleans poorly.
If problems continue, check the heating element as it is very possible that it has failed and the dishwasher needs to get to the proper temperature to activate the detergent. Also check to see if the holes in the spray arms are not blocked with debris.
If the heating element is working, then the wash pump motor has begun to fail and you need to decide to replace it or replace the entire dishwasher.
Posted on Apr 08, 2009
  • 630 Answers
SOURCE: Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Posted on Jul 02, 2009
bobicehouse
  • 1524 Answers
SOURCE: Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
Posted on May 19, 2010
Why is my soap not dissolving in the dispenser
could be a few things, could be the spray arms aren't turning and washing the soap out more likely tho is it isn't heating properly as this is the main thing that dissolves the soap and washes the dishes, are the dishes hot when you open the dishwasher?
Oct 07, 2014 | Samsung Dishwashers
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
