Question about Refrigerators
My fridge is freezing food how do I fix it - Refrigerators
awcforever
  • 359 Answers
SOURCE: Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 68 Answers
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Posted on Mar 30, 2009
  • 70 Answers
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Posted on Aug 10, 2010
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Jul 15, 2014 | Refrigerators
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge freezing food. Thick wall of ice at back of fridge. Turned down to lowest setting and still freezing.
heatman101
Jan 27, 2011 | Hoover Refrigerators
THE FRIDGE PART OF MY FRIDGE FREEZER ,FREEZES ITS CONTENTS.IT IS A HOOVER FRIDGE FREEZER MODEL NO.HNMF2805A-80
heatman101
Jan 26, 2011 | Hoover Refrigerators
The fridge part of my fridge freezer is freezing up
heatman101
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
heatman101
Jan 22, 2011 | Refrigerators
The fridge part of my fridge freezer keeps freezing my food. Doesn't matter which setting i put it on.It's suppose to be frost free. Can it be fixed?
heatman101
Jan 16, 2011 | Refrigerators
The fridge section of the appliance is not automatically defrosting the fridge is on the lowest setting but still manages to freeze food and drinks solid
heatman101
Jan 14, 2011 | Refrigerators
My SxS model 25 GE fridge is freezing food on the fridge side. I have turned it down to 1 and it still freezes the food.Also my water dispenser does not work. Can the 2 problems be related? How can these...
heatman101
Jan 05, 2011 | GE GSS25LGM Side by Side Refrigerator
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
