Question about GE Washing Machines
I have a GE Adora top-load washing machine. The washer fills up and overflows with water on all settings. Any ideas why?
Its almost like a sensor is broken and it keeps it from moving to the next washing stage. It worked fine last week. Today, no.
  • 57 Answers
  • You could have a bad level sensor or a pinched/severed/unattached vacuum hose which goes to the sensor device. The washer cannot determine how much water the tub is filling so the water keeps going in. I would check that the vacuum hose is simply not connected and that would be the easiest fix. The sensor device is usually located inside the control panel area and you can start there.
Posted on Dec 28, 2016
Not geting the cold water. Only once and a while even though set on Bright colors
Fixing a Washing Machine with Slow or No Cold Water Fill ...
? 7:40
www.youtube.com/watch?v=c5r49nuMjao
Feb 10, 2014 - Uploaded by SamuraiRepairman On washers with this problem that do the rinse cycle with coldwater only, the ... Top comments .... It's a front loading machine so I can't open it when it's on. .... GE Washing Machine Repair - Water Overfills, Overflows Washer ...
Aug 09, 2015 | GE WHSE5240D Top Load Washer
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
Washing machine does not cut off at the preset capacity.
check to make sure your drain hose is positioned higher than the highest water level in the machine, loop the drain hose up higher than the drain and secure it to keep the water from siphoning out.
May 29, 2010 | GE Profile WPRE6100G Top Load Washer
Overflowed on Large load size
i think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Oct 29, 2007 | GE WJSR1070A Top Load Washer
Clothes washer overflows
take the hose off at the pressure switch and blow through it if there are no restrictions then you have a faulty pressure switch let me know how you make out
Sep 11, 2007 | GE WPRB8050D Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
