Question about Breville Coffee Makers & Espresso Machines
Hi my Nespresso Breville U and Milk capsule Machine model Bec300mw White. Which purchased on 29/09/2013, has decided not let the coffee come out, as I noticed it has starting leaking water today.
  • 5 Answers
SOURCE: nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Posted on Aug 30, 2009
SOURCE: coffee not hot enough
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Posted on Dec 05, 2009
SOURCE: Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Posted on Jun 09, 2010
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Posted on Sep 05, 2010
  • 4 Answers
SOURCE: hi, i cannot get water
You can download the instruction manual from various places online; the instructions for the automatic and manual versions are slightly different but you can find them here:
www.eirvik.is/gogn/L/m100.pdf
www.eirvik.is/gogn/L/m100_automatic.pdf
As a first step I would suggest checking that the water can get out of the tank (just touching it with your fingers (over a sink!) should let drips out). It not, try cleaning that. You could also try descaling it (as in the manual). By the way, if the machine is less than three years old and you still have proof of purchase the Nespresso club will honour the warranty and fix it free of charge; if not, give them a call anyway and see what you can get them to do for you.
Posted on Sep 02, 2011
My Nespresso milk frother is not working (but there is power), what could be the problem? Where can I get it fixed?
I would contact Nespresso directly or the store/website where it was purchased. Depending on where it was purchased you might be able to exchange it through the seller, or get it repaired/replaced by Nespresso.
Sep 03, 2015 | Nespresso Aeroccino 3 White Milk Frother
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
I need a new lid for the Aeroccino 3. Where can I order it?
You can order these usually from the place from where you purchase your Nespresso capsules, either on line or in a Nespresso Boutique. Or if you have a toll-free number, they can do it for you also.
Oct 11, 2014 | Nespresso Aeroccino 3 White Milk Frother
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
My Nespresso Xn250140 U doesn't work. Why?
Check the hole where you put the capsule, are there any faults or obstructions visible? If not be very suspicious of your capsules, there are lots of brands of Nespresso coffeemakers and the capsules have slight variations between the different brands. The variations are almost invisible but enough to prevent the wrong capsules being used.
Jan 28, 2014 | Krups Nespresso Xn250140 U Coffee Machine,...
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Oct 03, 2009 | Nespresso Lattissima 660.R
Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Dec 24, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso C100
I just posted that I had the same problem, and then I thought to call Nespresso. They suggested trying a different capsule, as nothing actually holds it in place, other than its own lip. Sometimes a capsule (or sleeve of capsules) will have a defective lip, and that will cause it to drop right through rather than holding itself in place.
Oct 23, 2008 | Nespresso Essenza C100 Espresso...
Coffee Makers & Espresso Machines Logo
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
