Question about Optics
LG front load washing machine won't fill when cold temp. selected, still fills with hot
Model WD14030FD
  • 91 Answers
SOURCE: Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Posted on Jan 04, 2009
skotkolr
  • 558 Answers
SOURCE: Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Posted on Apr 07, 2009
  • 87 Answers
SOURCE: Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Posted on Jun 14, 2009
canbruce75
  • 1776 Answers
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Posted on Jul 19, 2009
beltronic205
  • 1474 Answers
SOURCE: LG f1256qd front loading washing machine, during
Sounds like too high water pressure, could also be dirt in fill valve / faulty valve. Good luck
Posted on Oct 03, 2009
LG front load machine won't fill when cold water selected, still uses hot water
Some hot water is admitted on the cold cycle to dissolve detergent (especially powdered).
Dec 27, 2016 | LG Washing Machines
My washer wm2277h does not have cold water just hot water..Can someone please help me
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 23, 2011 | LG WM2277H Front Load Washer
Machine squeals when filling
Hi just read your posting.Now what temp of water are you selecting for the wash cycle,is it warm, cold, or hot.Try this,Select hot fill then select cold fill and please reply on whether the squeal stops on either hot or cold fill.Looking forward to your reply.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
Cold water Washes
Apr 07, 2009 | LG WM-1832C Front Load Washer
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Optics Logo
26 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
