Question about Refrigerators
I fridge is freezing the food how do I fix it and there is no way to a just it
  • Refrigerators Master
  • 5,323 Answers
Fridge/freezer freezing up- and no fan or air circulation:
first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.
AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
God is so good: so this is why I give free advice so please thank him not me.
Posted on Dec 27, 2016
awcforever
  • 359 Answers
SOURCE: Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 68 Answers
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Posted on Mar 30, 2009
  • 70 Answers
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Posted on Aug 10, 2010
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Jul 15, 2014 | Refrigerators
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge freezing food. Thick wall of ice at back of fridge. Turned down to lowest setting and still freezing.
heatman101
Jan 27, 2011 | Hoover Refrigerators
THE FRIDGE PART OF MY FRIDGE FREEZER ,FREEZES ITS CONTENTS.IT IS A HOOVER FRIDGE FREEZER MODEL NO.HNMF2805A-80
heatman101
Jan 26, 2011 | Hoover Refrigerators
The fridge part of my fridge freezer is freezing up
heatman101
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
heatman101
Jan 22, 2011 | Refrigerators
The fridge part of my fridge freezer keeps freezing my food. Doesn't matter which setting i put it on.It's suppose to be frost free. Can it be fixed?
heatman101
Jan 16, 2011 | Refrigerators
The fridge section of the appliance is not automatically defrosting the fridge is on the lowest setting but still manages to freeze food and drinks solid
heatman101
Jan 14, 2011 | Refrigerators
My SxS model 25 GE fridge is freezing food on the fridge side. I have turned it down to 1 and it still freezes the food.Also my water dispenser does not work. Can the 2 problems be related? How can these...
heatman101
Jan 05, 2011 | GE GSS25LGM Side by Side Refrigerator
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
