Question about LG Washing Machines
LG front load machine won't fill when cold water selected, still uses hot water
Model WD 14030FD
    Top Expert:
  • LG Master
  • 39,324 Answers
Some hot water is admitted on the cold cycle to dissolve detergent (especially powdered).
Posted on Dec 27, 2016
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
Lg washing machine error message
Possible that water solenoid valve died. Unplug the unit to clear error code, and try to fill using only hot water. Try the same procesude using only cold water.
May 02, 2009 | LG Washing Machines
I have tried several times to use cold cycle and the clothes always come out very hot this even happens on the warm cycle. Why wont my machine except cold water?
this can get indepth but first check your hoses and make sure cold is cold and hot is connected to hot. then check the valves by selecting a hot cycle and check water at filling to see if it was cold or hot, if your unit has a heater make sure you dont select sanitize or very hot. then post correct model and heater info. to advise further
May 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
LG WFT653A, water continuosly filling
that solinoid must be conected rong
sean it before
Jan 22, 2009 | LG WD-14124RD Front Load Washer / Dryer
Tub filling with water after cycle is finshed
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Nov 07, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
