I have a 1964 Rockola Princess model 424. Powers on, however the turntable no longer turns, arm wont move up & record holder cage will not spin. Toggle switch of ON/OFF/OPER only works in"On" mode.
  • 92 Answers
SOURCE: Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Posted on Oct 11, 2008
  • 104 Answers
SOURCE: JVC L-E5 Turntable arm will not move to the record.
This turntable is linear tracking, meaning that the tonearm slides from side to side. Inside there is a belt coming off a motor and over to a pulley that will move the tonearm from left to right n right to left. If you feel qualified it can be replaced with moderate from the bottom after removing the bottom cover with the power OFF. the belt can be found here.
Posted on Feb 11, 2009
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
  • 5318 Answers
SOURCE: Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Posted on Feb 02, 2010
Throw it from a second story window then smash it with a sledgehammer. That's what I plan to do with mine.
Posted on Jun 03, 2010
I have a rockola 444. The record wheel rotates continuously. but the selector arm never selects a record. What might be the problem? Thanks,
When you select a record the turntable motor is energized and the big wheel that holds the records should start turning...does that happen?
Nov 10, 2017 | The Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Rockola 424 jukebox
Check the main gears at the bottom of the gripper arm as these get gummed up and need to be free.It sounds like it has not finished it's cycle as the last bit is dropping the arm. WATCH YOUR FINGERS as the motor won't stop until the switch is hit on the cam at the back of the tone arm.
Aug 20, 2014 | Audio Players & Recorders
My rockola 424 turns but wont play
Are all the gears at the base of the gripper arm free to travel their full distance?
Stop spinning
If it used to start spinning when the arm was move towards the record, then it's likely that the arm is connected to a switch which is now faulty and the contacts have closed and wont open. You might be able to get to it from underneath the deck. It might have just gone out of shape and could be bent back.
Aug 27, 2013 | Technics Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Rockola 464 jukebox. arm that holds needle will not move over to record
The turntable will need to be removed, the pladder should be taken off with the c clip to inspect the gears, I would not be surprised if the grease has gone hard and is interfering with the cycle. Flip the turntable over to check for any restrictions. If it is a grease issue the old must be removed before applying new. Please keep me posted on your progress and if I can be of further service don't hesitate to ask.
Jan 12, 2011 | Audio Players & Recorders
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
May 06, 2010 | Philco (R) 841.205 CD Shelf System
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
37 people viewed this question
