Question about Sewing Machines
There were no instructions with the needle threader
  • Sewing Machines Master
  • 11,177 Answers
Unable to help without the make & model.
Posted on Dec 27, 2016
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
Usually, the needle needs to be raised so the needle eye will match the threader. However, perhaps your threader has been bent or inadvertently pushed up or out of position.
Jun 06, 2017 | Sewing Machines
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
The needle threader is not lining up with the needle. how do I lower the needle threader?
You don't need to adjust the needle threader. You need to adjust the height of the needle so it meets the needle threader. Just hand rotate the hand wheel (always toward you, never backward!) until the needle is at the correct height for the threader.
Apr 21, 2016 | Sewing Machines
Why won't needle threader go down low enough to meet the hole in the needle?
Try raising the needle so the threader does not have to go so low. The owner's manual should have instructions on what height the needle should be set for using the threader.
Here is the information from the owner's manual (Page 20):
Auto needle threading device
Net
If using special threads which wind quickly off the
thread spool, attach a net to the spool before using.
Cut the net to match the size of the spool.
1 Net
2 Thread spool
3 Spool pin
4 Spool cap
1. Guide the thread through the wire loop thread
6
guide (number "6") and gently pull the thread
towards you.
2. Lower the presser foot.
3. Lower the needle threader lever until it stops.
Hook the thread into the guide and pull it
across to the right.
1 Wire loop thread guide
2 Needle threader lever
3 Guide
The needle threading device CANNOT be used
while the needle is LOWERED.
4. Push the needle threader lever toward the back.
Check to be sure that the hook has passed
through the eye of the needle and route the
thread under the metal guides and the hook.
Pull the thread toward you and check that it is
being held by the thread hook.
Here's where you can find the manual instructions:
http://www.manualslib.com/manual/355776/Brother-Pe-180d.html?page=20#manual
Oct 31, 2015 | Brother Disney PE-180D Computerized Sewing...
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
How do you use a needle threader for a plus 1 viking sewing machine
If it's the viking needle threader that was made for this machine, you would mount the needle threader over the needle screw. The part that fits over the needle screw of the needle threader is an eccentric. You rotate it until the hook of the needle threader slips into the eye of the needle. Once that happens you mearly put the thread in front of the threader hook and pivot the needle threader back out of the needle.
Apr 26, 2011 | Husqvarna Sewing Machines
How do I use the automatic threader? The diagram in the instruction manual just shows the threader but doesn't show how to get the thread in.
When you have the threader engaged to the needle hold the thread between your two hands horizontally and slide the thread behind the needle starting from the bottom up until you feel it stop then pull the threader gently out toward the back of the machine. Sometimes it takes a few tries to get the hang of it
Jan 20, 2010 | Sewing Machines
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
Aug 22, 2009 | Sewing Machines
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
