Question about Panasonic Televison & Video
Panasonic 50inch plasma TH-P50X50P. Accidently unplugged tv and ps4. ps4 comes on but tv doesnt.
No red standby light. power cord fuse good
  • chris winegard
    chris winegard Dec 27, 2016
    ty. I dont understand why i need to replace parts for something that just got unplugged. is this a bad make? I surely will not buy a panasonic again especially when it gets unplugged and i gotta buy parts. smh
  • chris winegard
    Its like owning a car running it out of gas and having to buy a motor!
    Top Expert:
  • Panasonic Master
  • 75,032 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 27, 2016
How do I fix a Panasonic Plasma TV that won't power on?
Aug 12, 2015 | Panasonic Viera TH-50PZ85U Plasma TV
Flashing standby light
Flashing red light can sometimes be fixed by holding down the power button on TV until it stops flashing then turn it off then on again. Disconnect everything except power cord before trying this. Mine was fixed this way and saved $500+ repair. Still going over 6 months on. Worth trying.
Apr 08, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
TH-42PD50U 42" plasma from Panasonic. The TV tipped over and won't turn back on. The red power light just keeps flashing on and off.
Try to unplug and replug the power cord. If TV remains unchanged you need to call for service. The power supply board was defective. In worse case, the Y and buffers are defective, too. There are many steps needed to figure out the exact defective board. You need help from TV repairer unless you want DIY.
Aug 13, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv will not come on I have a panasonic viera th-50px80u it was connect to a power surge and the outlet has power but the cord to the tv is good and is connect to the wall outlet but tv does not come on is...
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Aug 02, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
