Question about Brother Sewing Machines
How to install needle threader no. XD154921 on a Brother Innov-is 2500D embroidery machine
bargainbox
  • 1388 Answers
SOURCE: threading the needle of the embroidery machine
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until remedied....re-tighten screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
Posted on May 23, 2008
  • 19 Answers
SOURCE: how to use automatic threader on the pe180d embroidery machine
make sure needle is in the highest position before you thread
mary h
Posted on Jan 06, 2009
talk2ginny
  • 34 Answers
SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Posted on Jan 31, 2009
  • 109 Answers
SOURCE: brothers pe150 embroidery machine will not let the needle pick up lower thread
It sounds like the timing is off and needs an authorized repairman.
Posted on Aug 23, 2010
  • 1788 Answers
SOURCE: The needle threader on my Brother SE350 sewing
It should just slide right back on, just line it up so that the threader tip goes through the needle eye. At least. that was how I did my Singer and I would think that they all work the same way
Posted on Sep 26, 2010
1250 embroidery machine how do you thread for a double needle?
Do you mean the Brother Innov-is 1250D embroidery machine? Insert your twin needle. Follow the normal directions for threading the upper thread and manually place this thread through the eye of the left-hand needle from front to back. For the right hand needle, insert the extra spool pin in the bobbin winder shaft. It gets put on perpendicular to the shaft. Swing down the spool pin so that it is horizontal, pointing towards the needle bar. Place another spool of thread on this spool pin and secure it with the appropriate-sized spool cap. The thread should come off the top front of the spool. Follow the threading directions for the upper thread from step 8 (the thread guide cover) through step 10. Do not run this second thread through the needle bar thread guide. Manually thread the right hand needle eye. Make sure to use the zig-zag foot with the twin needle.
The directions for threading the machine when the twin needle installed is on page 36-37 (pages 38-39 of the PDF) of the manual. The manual is available from Brother support on the product page: http://www.brother-usa.com/support/modelinfo.aspx?R3ModelID=NV1250D . The direct link to the manual is currently: http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_Innov_%c3%ads%201250D_EN_2825.PDF .
I hope this helps.
Apr 09, 2018 | Sewing Machines
Brother Se 400 sewing machine
The needle threader is a very delicate item on the machine. What is your question? As always, please have a trained technician make the repair for you, they have access to any parts you may need and they can do it safely too!
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Brother Sewing Machines
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
How do I replace the wire that threads the needle on my brother sewing machine
it would probably be a good idea to take the machine to a sewing machine shop to have the needle threader fixed
May 21, 2012 | Brother Sewing Machines
I have a Brother 750D innov-isi think he tenchion
If the thread is pulling through the top of the fabric slacken off the top tension to about 4 and tighten the bobbin tension slightly by turning the screw on the bobbin case about a quarter of a turn clockwise and test.
Apr 06, 2010 | Brother SE-270D Computerized Sewing...
How to use automatic threader on the pe180d embroidery machine
mary h
Jan 06, 2009 | Brother Disney PE-180D Computerized Sewing...
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
