I have horizontal green lines going across bottom half of screen with good audio.
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
There are many reasons for this fault. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 28, 2016
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Our Toshiba Regza LCD TV has developed a thin white vertical line down one side and a green horizontal line across the middle. The bottom half of the TV screen then comes and goes in muted and faded...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in solving the problem....
Aug 06, 2011 | Televison & Video
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
H Lines on the left side of the screen
just in case you came across this - it is the light engine! $950 - thanks mits for complete junk
Oct 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
