According to the manual, there is an accessory that covers the feed dogs. (Shown as an accessory on page 4.) So the feed dogs should not raise or lower other then during normal sewing action of moving the fabric.
Singer 6235 User Manual Page 24
Singer 6235 User Manual Page 6
SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
SOURCE: Feed dogs won't raise up again
The Kenmore is made by Janome. The Janome has a little cam (lever) that when flipped, is pushed out of the way so the feed dogs will drop down. Over time (read too long between thorough cleaning and oiling), the cam will stick over where it is pushed. It is physically pushed when dropping the feed teeth, but it when you flip the lever back, it relys only on a spring for it to pop back. It only has one spot in a complete hand wheel rotation to pop back, and if it sticks at all, it wants to stay down.
Solution:
Hold the feed dogs up while turning the handwheel. This can help it pop up. If that doesn’t work, remove the two bottom screws under the free arm and look for the cam. It like the on the very end of the machine even left and further back from hook. As you turn the handwheel, you’ll see it rotate as a lopsided wheel on the shaft. Gently push it right while you turn the handwheel. Then clean and oil it so it will move more freely
Kent
Solution:
Kent
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
SOURCE: The feed dogs on my Singer model 7444 will not
This may not be a simple job as "plastic" machines have to be snapped apart and back together just right.
The problem could be at the switch or somewhere between the switch and feed dogs.
Check with a Singer dealer for an estimate for the repairs before you take it apart and find you cannot get it back together.
