Question about Health & Beauty
I have got a explorer 4 mobility scooter and I am having some problems with the leavers at first of all there tight to use and them I can get a little way down the road and then they go real lose
  • Health & Beauty Master
  • 1,197 Answers
Hi if u r talking about the WIG WAG leaver .,..U might have to replace it... Cheers
Posted on Dec 27, 2016
Squeaking axles
It's almost certainly a slightly binding brake, it often happens, especially if you have a sticky hand brake cable/ leaver. I've posted a full answer here as another Pride post.
Jun 10, 2014 | Pride New Mobility Victory XL 4 Wheel...
What is the lever for
There are several
the right hand tiller leaver is for adjusting the tiller pitch
the left hand tiller leaver is the hand brake - keep that lubricated and squirt a bit of wd40 down the inside of the brake cable if you can.
The leaver on the right of the seat post is the motor brake freewheel leaver, the seat leavers are for swivel, back pitch.
Apr 05, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Seat
Oh yes it will! They can be very stiff and heavy, get help and mind your back! Release the seat swivel leaver and wiggle the seat left and right as you rupture yourself lifting..... You probably need help I do these days.
Jul 28, 2013 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
I have a PRIDE scooter. It is a Victory model but I don't have any serial number or exact model #. It turns on, goes a little and then "bucks" ir stops completely. When I take out the key and...
1)Make sure the battery's fully charged..
2)Your brake lock and unlock leaver under your seat..be sure its totally engaged in the locked position in other words ''all the way pushed down''.
3)Take the shroud off the back, this can be done by removing the seat, hold the seat leaver up towards you ,Now you should be able to rotate the seat when you have lifted that leaver when it does rotate lift up the seat it will come off.now that the seat,the shroud are off. you will be able to see the battery's make sure the connections are good and tight...
4)Tilt the scooter over on its side there is a grayish white cable this is your front-to-rear cable follow it from the front to the back ,make sure there is no cut or broken spots'which would be a spot on the cable that looks as if its been scraped against the ground .If there is a brake in that cable it will need replacement.
* Put the shroud and the seat back on the scooter if everything checks out ,Get on the scooter turn the key make sure that needle goes all the way to fully charged mark go slow tap the top of the console if it stops faster than it did before or doesn't at all your looking at a new key switch.
hope i was helpful good luck.
Jan 16, 2011 | Pride Mobility Victory 3 Wheel Electric...
Removing the chair or seat on a electric mobility sccoter
the seat should just lift off or may have to lift swivel seat leaver
ted mobility centre penge
Apr 15, 2010 | Electric Mobility Mobility Electric Power...
Rally 4. The steering seems to be stiff or tight.
hi,
ok now carefull tip the scooter onto one side, look at where the steering column attachs to the main frame, it's here you should find a bearing type collar, now you need to losen this and lubricate with a light gears, best to use a waterproof gease then tighting the collar up but
not too much otherwise your steering will again become tight.
Regards
GeWiz.
Feb 15, 2010 | Pride New Mobility Rally 4 Wheel Scooter
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
