Question about Amazon Fire TV Stick
How to install builds in fire tv stick without computer
Can I surf the internet with the Amazon Fire Stick?
Yes you can. In order to surf the Internet with the Amazon Fire stick you need to install a web browser. Here's a link to an article that explains how to install Chrome on the Fire Stick How to Install Google Chrome on Amazon Fire TV Stick Low Tech Grandma
Once installed, navigation is a bit tricky. Here's another article explaining how to navigate Chrome using the Fire Stick remote: How to Navigate around Google Chrome on Amazon Fire TV Stick Low Tech...
Oct 17, 2017 | Televison & Video
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
I have accidently wiped KODI off my fire stick how do I get it back?
You can reinstall kodi on firestick with a lot of methods but one of them is given as follow
Similar to other methods, this method too requires you to enable installation from "Unknown sources." Once you do it, follow these steps.
Before these steps
STEP 1: Search FireDL on your Fire Stick.
STEP 2: Install FireDL and Open it.
STEP 3: Type 600003 at the top blank space.
STEP 4: The above code will automatically convert to the Kodi APK URL and download will start without any further actions from your side.
You can then install some great addons and builds to further enhance your experience.
19 Best Kodi Builds To Experience The Colors Of Kodi
Apr 14, 2017 | Amazon Fire TV Stick
How to get titans to play on my fire tv stick it says failed to resolve url
Sounds like you have a build that needs an update. I suggest using no limits magic build which you can find on you tube. I have been using this build for almost a year and they lately have been updating about every 2 weeks. Why this build, because I find it to be most complete of all the ones I have seen. They have 2 versions one of which is made for fire stick.
Mar 26, 2017 | Amazon Fire TV Stick
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide -
If any further issues, please let me know.
Mar 06, 2017 | Televison & Video
How can I get the KODI app for my fire stick
Here's an article that explains the process. It also provides two videos for adding Kodi to the Amazon Fire Stick Jail Break Amazon Fire TV Stick
Nov 13, 2016 | Amazon Fire TV Stick
I want to jailbreak my Amazon fire stick
Hi Jimmy
I guess you need to do some research on the internet then.
This site helps people to fix real faults.
We don't advise hacking (jailbreaking)
Good Luck
Mar 01, 2016 | Cell Phones
Can i install a amazon fire tv stick the u s b will not plug in Customer Reviews: Amazon Fire TV Stick, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ). Customer Discussions: Fire stick and Samsung TV issues, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
Amazon Fire TV Stick Logo
23 people viewed this question
Top Amazon Televison & Video Experts
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Ron Harvey
Ron Harvey
Level 1 Expert
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
