Question about Magnavox 19MF330BF7 19 in LCD TV
Magnovox 19" LCD tv sometimes won't turn on without unplugging the power cord and replugging it in.
I'm using my 19" Magnavox LCD tv as a second monitor. However, sometimes when I turn it on it just keeps a blank black screen and won't turn on. I have to unplug the power cord and plug it back in to get it to turn on and function properly. This doesn't happen every time, but probably about 50% of the time. I haven't been able to figure out what's causing it.
  • 26 Answers
SOURCE: Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Posted on Feb 25, 2008
Fix-4U
  • 293 Answers
SOURCE: LCD screen goes black repeatedly
Your inverter and AC Adapter is burnt out, need to be replaced.
Drop me a note, I'll give you a good price. repair@3rd-rocks.com
Posted on Mar 14, 2008
SOURCE: LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Posted on Apr 25, 2008
  • 1548 Answers
SOURCE: westinghouse lcd monitor 19" - screen turns white
Fade to white might be caused by a bad or open connection to the backplane or bias voltage setting of the LCD. Check the connectors and cables between the LCD and the main board. Also, look for loose or disconnected ground wires.
Posted on Dec 18, 2008
SOURCE: 19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Posted on Aug 16, 2009
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
I replaced an apparent blown fuse, TV still won't power on.
Most likely your power supply is damaged and will need to be replaced. Sometimes, power supply manufacturers add additional "fusible resistors" to provide additional protection.
Jan 05, 2013 | Magnavox 19MF330BF7 19 in LCD TV
Hi my son got a 19inch emerson tv for his 2nd birthday and now anytime it gets plugged in it flashes different colors and the buttons does't work and the only way to turn it off is to unplug it!! can this...
Press the the cursor key up followed by down and power the TV off with the remote or the TV itself. Please use the original remote for this. Unplug the TV for a few seconds...replug and power the TV on. The second thing to try...press the cursor key left followed by the right key. Power the the TV off with the remote or the TV itself. Unplug for a few seconds...replug and power up the TV. Some of these TVs left the factory in the service mode. The fix is pretty simple. Thanks asking and show a few hands of support!
Feb 14, 2011 | Emerson LC195EM9 19 in. LCD TV
The tv shut off by itself, it has 110v getting thru the cord but willnot turn back on. I can't find a reset button do you have any suggestions?
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory.Now the tv should be working again.If still have the same result.The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 05, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
TV WILL NOT COME ON. LED FLASHES YELLOW FOR A FRACTION OF A SECOND WHEN POWERED UP. BUT NO SOUND OR VISION.
Tries unplug,replug the tv back like an hour later.Now,the tv,will reset itself back to the factory setting.Now,the tv should work.If not,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 19, 2010 | Goodmans GTVL19W17HDVF 19 in. LCD TV/DVD...
I have a philips flat screen (19 inch)...It will not turn on at all...no blinking light...no noise...not a thing... I've tried different outlets...unplugging power source and replugging. This tv was...
You have a power issue I would try to replace the power board.I repaired a phillips magnavox same problems.I purchase the board for about 75$ and got it back to customer.Sometimes you can repair the board and sometimes you cant.
Sep 29, 2010 | Philips Televison & Video
No picture and the power button on the tv just blinks when u turn it on
Unplug,replug tv it back about an hour.The tv should reset it self back to factory setting and work.Same problems,occur the tv power supply board it dead.That the board power,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 23, 2010 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox 19" LCD TV: no sound
it sounds like a dry joint,where the solder cracks if you tap it on the side and it alters its state then you have to locate this cracked solder and re solder,sometimes not visible though
Jul 19, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnovox HD2763C401 dead sometimes
MINE STARTED DOING THE SAME THING RECENTLY BUT HAS WORKED WITHOUT A GLICHE FOR 22 YEARS
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 19MF330BF7 19 in LCD TV Logo
32 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
